dskogg Posted December 11, 2018 Share Posted December 11, 2018 I have a drop floor 24" and a half wall with a stair bumped up against it..ca wants to draw a wall at ceiling? If i pull stair away it goes away but then half wall going down stairs is not sloped any more Anyone have an answer? Link to comment Share on other sites More sharing options...
AvoyeDesign Posted December 11, 2018 Share Posted December 11, 2018 Never seen this before, so I can't even speculate on the cause. If you post the plan I could look at it for you. Link to comment Share on other sites More sharing options...
javatom Posted December 11, 2018 Share Posted December 11, 2018 I'm not sure about the wall situation but you might want to add another riser. 24/3= 8". It will be out of code compliance. 1 Link to comment Share on other sites More sharing options...
justmejerry Posted December 12, 2018 Share Posted December 12, 2018 Is it an attic wall drawing in? Never had same situation yet myself. I agree with Rod, post the plan. 1 Link to comment Share on other sites More sharing options...
AvoyeDesign Posted December 12, 2018 Share Posted December 12, 2018 16 hours ago, justmejerry said: Is it an attic wall drawing in? Never had same situation yet myself. I agree with Rod, post the plan. That was my initial thought, bit the OP states it goes away when he moves the stair away from the wall, which is a bit unusual. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 12, 2018 Share Posted December 12, 2018 I'm guessing it's a ceiling height issue...room above is open below for some reason? Link to comment Share on other sites More sharing options...
dskogg Posted December 14, 2018 Author Share Posted December 14, 2018 All I did was change that floor to -24”.. so there is no room above. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted December 14, 2018 Share Posted December 14, 2018 50 minutes ago, dskogg said: All I did was change that floor to -24”.. so there is no room above. Please post the plan so we can take a look. Link to comment Share on other sites More sharing options...
