rockyshepheard Posted November 21, 2018 Share Posted November 21, 2018 I have created a perimeter on the first floor. Then created a second floor. Then created a smaller perimeter for the 'floor and a half '. I build the roof and it looks good except all the walls are missing on the floor and a half level. I thought you needed walls to make a roof unless you used room dividers. I didn't use room dividers and got the same effect somehow. I would prefer to see the walls. Any thoughts as to what tick I may have erroneously ticked? Thanks! Link to comment Share on other sites More sharing options...
rockyshepheard Posted November 21, 2018 Author Share Posted November 21, 2018 Eric, sorry, yes. Perimeter means walls. i cannot post it until morning but will then. Thanks. Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 Your 1st. floor roof is cutting off the 2nd. floor walls. Link to comment Share on other sites More sharing options...
rockyshepheard Posted November 21, 2018 Author Share Posted November 21, 2018 Ah hah! Is there a way to prevent that from happening? Thank you! test.plan Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 Try rebuilding the roof. Be sure you have room definition on the 2nd. floor. I'll look at your plan in a little while if someone doesn't beat me to it. Worse case would be to edit the roof planes. Should only take a minute to do that. Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 Not sure what's going on but I could fix it manually. Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 Edited 1st, floor roof manually based on your wall placement. Personally I think you need to redesign this. Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 If you want the plan, let me know. I opened it in X10. Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 Here is your plan with roof edited to walls as drawn. test.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted November 21, 2018 Share Posted November 21, 2018 2 hours ago, tommy1 said: Not sure what's going on but I could fix it manually. Yep some strange goings on ..... I think while you Practice? Rocky , I'd try with a new CA OOB Default Template plan , it looks like the Roof Hole around the 2nd storey Walls isn't being generated for some reason... and like your other Thread there are weird little roof planes here and there, even using Auto Roofs..... Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 53 minutes ago, Kbird1 said: Yep some strange goings on ..... I think while you Practice? Rocky , I'd try with a new CA OOB Default Template plan , it looks like the Roof Hole around the 2nd storey Walls isn't being generated for some reason... and like your other Thread there are weird little roof planes here and there, even using Auto Roofs..... Yea. I did something similar in a new plan and everything generated just fine. Anyway, if I run into something that doesn't generate automatically correct, then I don't fight the program, doing it manually will get it done faster. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 21, 2018 Share Posted November 21, 2018 There is definitely a bug that needs to be worked out with that plan/situation. Please make sure to send things like that in to tech support. I have no reason whatsoever to think it's user error in this case. Link to comment Share on other sites More sharing options...
