Select Invisible room/Room Divider
jjifmeyer
What is the easiest way to select an Invisible (Wall Room) or Room divider Wall?
It literally took me 5 minutes to try to select this area.
This is the area under the Roof leading to outdoor Structure (Garage)
I eventually get it selected but it is hit or miss.
There must be an easier way.
You are having trouble because (as far as I can tell without the plan), there is really nothing to select.
Firstly do as Mark said and turn on select room before walls in Preferences.
You have a room with invisible walls, no floor and no ceiling (?) - so, nothing to select in 3D.
If you do have a ceiling, try clicking on that.
Otherwise, you may need to temporarily give the room a floor so that you can select the room.
Or, select it in plan view and do what you want to do there.
