M-Ferioli Posted October 5, 2018 Share Posted October 5, 2018 If I layout a crown molding polyline from the plan view, is there an easy way to select it and edit it? It is basically invisible and I can never seem to select it, the cursor just picks up the cabinets and other larger objects. I can get to it if I turn off major layers but was wondering if there is an easier way to maybe grab it from list of symbols in the current job? Or a way to see every symbol underneath the cursor and then pick the one you want to select? This really applies to all symbols that are stacked vertically but moldings seem to be the hardest to select. Thanks! Mike Link to comment Share on other sites More sharing options...
Chopsaw Posted October 5, 2018 Share Posted October 5, 2018 A list would be a great idea but for now you can use the tab key to drill down through the nearby items although sometimes it is easier to turn off or lock some of the items that seem to always be selected first. Link to comment Share on other sites More sharing options...
MarkMc Posted October 6, 2018 Share Posted October 6, 2018 1 hour ago, M-Ferioli said: If I layout a crown molding polyline from the plan view, is there an easy way to select it and edit it? Few things you can do. Use a layerset (or in my case as part of an annotation set) that limits what is shown on the plan. I have an annoset that I use to dimension wall cabinets that can be used for molding with less clutter. Less Clutter- It also helps if you -select molding from library first BUT don't just go and click, with molding selected then select molding line (or hot key it which is what I do) If you select and then just click on the plan you end up with a closed molding polyline which you don't want. It helps to start with the molding that has the deepest profile first, add others later. Alternatively if you don't remember to select a molding first run the molding line beyond the cabinet so you can see it Link to comment Share on other sites More sharing options...
M-Ferioli Posted October 6, 2018 Author Share Posted October 6, 2018 Thanks for the help everyone! I learned something new from each reply that I've already applied and am truly grateful for all your help. I'll make a note about annotation sets and explore that in the future, sounds helpful for sure. Link to comment Share on other sites More sharing options...
basketballman Posted October 6, 2018 Share Posted October 6, 2018 You can also increase the line weight and color it bright red so it really pops ... 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted October 6, 2018 Share Posted October 6, 2018 5 minutes ago, basketballman said: You can also increase the line weight and color it bright red so it really pops .. Now there is an amazingly simple solution. I may have to try that for moldings that are drawn in elevation that are less than a pixel in plan view and see if it works. Thanks. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted October 6, 2018 Share Posted October 6, 2018 13 minutes ago, basketballman said: You can also increase the line weight and color it bright red so it really pops ... That's what I do. I make mine the bright pink for exterior molding lines and yellow for interior - both on separate layers. Link to comment Share on other sites More sharing options...
MarkMc Posted October 6, 2018 Share Posted October 6, 2018 Ditto, I use blue for undercabinet and orange for room, didn't think to mention that. Link to comment Share on other sites More sharing options...
M-Ferioli Posted October 6, 2018 Author Share Posted October 6, 2018 Really good idea! Link to comment Share on other sites More sharing options...
