rafay22 Posted August 28, 2014 Share Posted August 28, 2014 I want to get the lower ground floor of the house to be fully open from the two sides, how do i lower terrain there ? Link to comment Share on other sites More sharing options...
lbuttery Posted August 28, 2014 Share Posted August 28, 2014 place elevation regions and set height as needed Lew Link to comment Share on other sites More sharing options...
rafay22 Posted August 28, 2014 Author Share Posted August 28, 2014 Thanks i just done that, its lowering the area but also the terrain wall. I want the terrain wall to be at one level from the top. Link to comment Share on other sites More sharing options...
rafay22 Posted August 28, 2014 Author Share Posted August 28, 2014 file 5.plan Link to comment Share on other sites More sharing options...
lbuttery Posted August 28, 2014 Share Posted August 28, 2014 place elevation lines on each side of the terrain wall set to desired height on each side may need other elevation regions Lew Link to comment Share on other sites More sharing options...
tommy1 Posted August 28, 2014 Share Posted August 28, 2014 Try using something other than a terrain path for your "terrain wall". A terrain path will follow the terrain. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 29, 2014 Share Posted August 29, 2014 Use a retaining wall with an elev. line either side , not a terrain wall which will follow the terrain as Tommy noted..... M. Link to comment Share on other sites More sharing options...
dshall Posted August 29, 2014 Share Posted August 29, 2014 Use a retaining wall with an elev. line either side , not a terrain wall which will follow the terrain as Tommy noted..... M. Never considered kbirds method, I might try it. I do not like Tommy's method. I think the best method is to put a wall in and designate it as retaining. Now here is the key.......... Adjust the height of the top and bottom of wall. Now put the height back to original elevation if you want. The key is once you have changed the elevation, it will STAY as you put it. Link to comment Share on other sites More sharing options...
tommy1 Posted August 29, 2014 Share Posted August 29, 2014 Use a retaining wall with an elev. line either side , not a terrain wall which will follow the terrain as Tommy noted..... M. KBird & Scott. Please read my post a little closer. I didn't offer any wall type to use or any method. I recommended NOT to use a terrain path for what he called "a terrain wall". You both actually agree with me. He used a terrain path and called it a terrain wall. Link to comment Share on other sites More sharing options...
