4hotshoez Posted August 27, 2014 Share Posted August 27, 2014 I have a jpeg logo with a line in it. I am trying to move the jpeg to line up with a vector line, but it keeps jumping either side of the line. Is there a way to fine tune the movement or an easy way to get them to line up? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 27, 2014 Share Posted August 27, 2014 use the arrow keys Link to comment Share on other sites More sharing options...
4hotshoez Posted August 27, 2014 Author Share Posted August 27, 2014 I did use the arrow keys and it jumped more. I am in Layout creating a titleblock Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 27, 2014 Share Posted August 27, 2014 Try turning off the Grid Snap. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 27, 2014 Share Posted August 27, 2014 Try grabbing the move handle, hitting tab, and then entering the correct angle and a very small measurement of movement. Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted August 27, 2014 Solution Share Posted August 27, 2014 Remember too that Layouts are measured in Paper Size. The Grids may be as much as 1/8" and you might need to move the Logo only 1/128". IAE, you could probably get very close with the Pt-to-Pt Move Tool. Link to comment Share on other sites More sharing options...
Bill_Emery Posted August 28, 2014 Share Posted August 28, 2014 Estimate the distance and then use the transform/replicate tool. You may not be exact on the first try, but should be able to zero in on it quickly. I often zoom in and draw a box and then measure it to get a close estimate of the distance. Link to comment Share on other sites More sharing options...
4hotshoez Posted August 28, 2014 Author Share Posted August 28, 2014 Point to point tool did it, Thanks Link to comment Share on other sites More sharing options...
