ACADuser Posted September 16, 2018 Share Posted September 16, 2018 Automated Foundation Size in a text? Might have asked this before but can't find it. I was trying to have a leader & text do display the Foundation Size from the foundation wall. Text like this CC Foundation 16x8 w/ 2 #5 rods Where 16 & 8 come from the wall, but I can't seem to find the foundation size. Also in the Foundation default only see one option for rebar number & size. The current house has at least 3 different foundation types and the number of rebar varies. And at times the size of the rebar may be different as well. Can it be that Chief only allows one foundation type setup for the entire house? Link to comment Share on other sites More sharing options...
MarkMc Posted September 16, 2018 Share Posted September 16, 2018 I don't know the answer - if it can be done you need one of the Gurus. The issue is that the foundation wall thickness is a property of the wall, while the height is a property of the room. If getting properties from two objects into a referenced macro is possible it's more advanced than anything I know how to deal with. Your other thread has similar problems-not a simple macro. What I can offer is when learning this stuff it helps to have a way to see what each object has that you can get at. Here is a macro that I got here (from Joe I think) that can quickly read the properties from an object. Import it into the TMM (text macro management) then when needed select an object, open TMM (I use a hotkey), scroll down to this macro and see what is available. There are other ways to get the information but this one is handy. Object Properties.json Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 16, 2018 Share Posted September 16, 2018 Alan, What you are trying to do is not possible with the current set of available properties of the Foundation Wall. Link to comment Share on other sites More sharing options...
dshall Posted September 17, 2018 Share Posted September 17, 2018 3 hours ago, ACADuser said: Automated Foundation Size in a text? Might have asked this before but can't find it. I was trying to have a leader & text do display the Foundation Size from the foundation wall. Text like this CC Foundation 16x8 w/ 2 #5 rods Where 16 & 8 come from the wall, but I can't seem to find the foundation size. Also in the Foundation default only see one option for rebar number & size. The current house has at least 3 different foundation types and the number of rebar varies. And at times the size of the rebar may be different as well. Can it be that Chief only allows one foundation type setup for the entire house? Yep, not a good question or request..... is the footing 8” thick or 8” deep....... I’m assuming 18” minimum depth and minimum 8” thick. (16” wide) Link to comment Share on other sites More sharing options...
ACADuser Posted September 17, 2018 Author Share Posted September 17, 2018 Thanks fellas, Yes I have joe's macro & no size info. The 8.375" refers to the stem wall thickness as the foundation is 16x8 I will add a request to Chief. Link to comment Share on other sites More sharing options...
