ARCHITECTURAL BLOCK IN CAMERA VIEW
Aamir77
Hi,
I am facing a problem and need your kind guidance in fixing the issue. I have made an architectural block and have stored it into my user catalogue for future installations which is a window grill.i have made a triple story house and on first and second floor grill is installed with the windows but on third floor whenever I try to fit in the grill with the window it disappears in camera view but remains present in plan view.what could be the cause?
38 minutes ago, rlackore said:
Have you checked the Z-value of the third floor symbol? Otherwise, I don't think we can help unless you post the plan file.
6 minutes ago, rlackore said:
I do not have this option to choose the height from the floor or offset from the ceiling and yes the problem is with offset. Because symbol is made at ground floor and if I try to put it on the 2nd floor it stays at its basic ground floor level in camera view. I am amazed at my own that how did I managed when I copy pasted the same symbol as of ground floor and it is showing both in plan view and camera view on the first floor!
Just now, rlackore said:
Have you tried exploding the block? Otherwise, post the plan.
exploding the block and rejoining the sticks into a frame is a tedious thing that's why I did not opt for this trial. If this way is the only solution, I better make a new grill on the third floor.
1 minute ago, rlackore said:
Why don't you create a new plan, insert the Architectural Block, explode it, then create a Symbol. You should have complete control of the Symbol when you insert it into your existing plan.
I really did not know this method before!
I had this problem a while ago. I believe the issue is that the blocks position defines where the blocks boundary cad box displays, the actual elements within the block will display according to their individual locations as defined within the block. You need to access the individual items within the block to make sure their location references are correct.
will i have to recreate the block after exploding to make it symbol again?
Here are the steps:
1. File>New Plan.
2. Insert the Architectural Block from your User Library into the new plan.
3. Select the Architectural Block and Right Click>Explode Architectural Block.
4. Open an Orthographic Full Overview.
5. Tools>Symbol>Convert to Symbol. Select the appropriate options as you progress through the symbol creation dialog box. Be sure to save the Symbol to your User Library.
6. Return to your existing house plan, and insert the Symbol on the floor you want it to display on. Select the Symbol and Right Click>Open Object>General>Size/Position.
17 hours ago, rlackore said:
Here are the steps:
1. File>New Plan.
Issue solved. Thank you for your kind attention and help.
    30212
    Monikafb
    Monikafb
  • Similar Content
    • By kylejmarsh
      I've noticed this for a while - my exterior camera get's messed up at a certain point so when I try to zoom out with my scroll wheel instead of the camera moving it seems to change the perspective angle - though when I check the camera dialogue box it's still set at 35-degrees.
      What gives? Not a big deal I just reboot the camera view but still is odd. Anybody solve this or is it a bug?
    • By GCCISarah
      Hi everyone-
      In the last several plans I have created in chief X11, using a Camera View with a Reference Display of the As-Built, I have the As-Built Reference Display file set to render as a Glass House view. The Glass House referenced model displays, but without any of the dark outlines to show the features of the model. I have included an image of a remodel I am working on currently, where the referenced As-Built shows as a faint blue shape. Nothing like the examples Chief gives of a reference display, below.
      Any thoughts on what setting I might be able to change to get the 'outlines' back. I have also included an example image from Chief I found online, which has the desired 'outlines' in black.
      This does ONLY happen when I'm using Glass House View as a *Reference Display* in the plan I'm working on. If I were working on a plan and change the rendering technique to Glass House, the outlines are visible. This only happens in Reference Display.
    • By GCCISarah
      Hi everyone-
      In the last several plans I have created in chief, using the reference display in a 3D view (referencing an as-built plan overlayed onto the remodel plan) with Glass House View, the Glass House View is very transparent, with no 'outlines' around the items in the drawing.
      It makes it quite hard to see what the existing vs. remodel.
      Any thoughts on what setting I might be able to change to get the 'outlines' back. I'll attach a photo of a kitchen I'm working on currently below, showing how faint the Glass House View is, vs. an example photo from Chief I found online, which has the desired 'outlines' in black.
      This does ONLY happen when I'm using Glass House View as a *Reference Display* on the referenced plan. If I were to delete the reference display plan, and just change the rendering technique of the Plan file I'm working on to Glass House, there is no problem. The 'outlines' show as desired.
    • By DaveCoyleJr
      Hey guys... I've been dancing around an issue that I simply need to tackle once and for all. Whenever I wish to build a simply visual layout, I get the perfect angle and hit "Send to Layout", "update Always" under Live View... This always spits out a box that is centered on my page and at the same size and scale... The issue is I can't figure out for the life of me how to edit this box. It is always unclickable and appears as if chief does not even recognize it. I literally can't even delete it and is usually forced to Ctrl-Z or delete the page and start anew.
      I know there is something small I'm missing here; To circumvent this issue, I simply "send as image" and I'm able to scale and fit; but then I proceed to have a hissy fit when clients want to change small things and I'm forced to go and "reframe" my entire model... PLEASE HELP! I just want to resize the live view to fill my layout page. or at least be able to delete it.
      EDIT: I'm on Windows X11 btw
    • By GCCISarah
      Hi all,
      All mirrors from the catalog(s) that I am placing show a bright yellow cast and pixels on the reflective surface of the mirror itself. The mirror IS reflecting the room around it, but the bright yellow color and pixelation never resolves itself. The first photo is the 'Standard' camera view rendering technique, where the yellow is at its brightest. The second attachment is 'Physically Based' rendering technique, where the yellow is faded a bit.
      I had no problems in X10, but this issue has been in all of my plans so far using X11.
      Any thoughts? The mirror material is set as a 'Mirror', with 100% reflection. I've not changed any defaults, preferences, or qualities about the mirror material or camera views that I could think would affect the reflective quality. Help appreciated.
