Member Statistics
Similar Content
By ChiefuserMathews
Hello, do we have batten board symbol in CA as wall type as shown in the section attached?
By ChiefuserMathews
I was wondering is there a way to rename a symbol so that the name appears in the schedule will be as required rather than the CA symbol name. eg. 2 way ceiling register, I want to rename it as supply air to reflect in my schedule. Is it possible? Any suggestions how i can achieve that?
By MikeCSD
Hello, I am the owner of Custom Structure Designs and a practicing, licensed, municipal Building Official with the State of Connecticut. Contact us if you are looking for design services for your project. We are also available for code consulting on residential and commercial projects.
Michael Roraback
Manchester, CT
860-682-4740
By nick9645
I'm looking for a Gas Range symbol or how to callout a Gas Range on a MEP Plan.
I tried searching google and this site all I got was Line drawings for a range.
Thanks,
Nick
By cjanderson66
I have designed a very large deck and the client wanted to take 2' off in one direction and another 3' in the other. I have custom framed the deck framing per the engineer and don't want to change the framing. The problem is that I need to rebuild the deck in order to not show the decking from overhanging the framing. Is there a way to just rebuild the decking and not the framing of the deck itself. as you can from the rendering shown below you can see that the decking overhangs the decking. Everytime I rebuild it it changes the framing per CA.
