Geyatautsilvsgi Posted August 23, 2018 Share Posted August 23, 2018 Hey guys, I got the the attached graph paper file from a client who wants his roof to look this way. The roofing is to be corrugated metal. I know this can be physically accomplished in the real world because the metal can be cut. However, I have been very unsuccessful in getting this to work in chief. I need to know if anyone has been able to complete a look like this and if so, how did you do it. Thank you in advance for your thoughts and input. J Link to comment Share on other sites More sharing options...
javatom Posted August 23, 2018 Share Posted August 23, 2018 I'm not sure that can be done in the real world. It would mean a metal sheet would have to twist. I'm not a roofer but I would check with one before I started figuring out how to model it. Link to comment Share on other sites More sharing options...
rlackore Posted August 23, 2018 Share Posted August 23, 2018 Eric has a point - you're plan diagram and your elevation do not match. Regardless, it can't be done as drawn, which is why you're having a difficult time modeling it in Chief. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 23, 2018 Share Posted August 23, 2018 The join between the roof planes must be angled or the closer wall in the graph paper sketch must be sloped at the baseline of the roof. Link to comment Share on other sites More sharing options...
rlackore Posted August 23, 2018 Share Posted August 23, 2018 You can raise the large roof to provide a wall against which the small roof can terminate: Or you can slope both roof planes in the same direction and join them along the common edge: Or you could create a hipped intersection: There are other possibilities as well, but what you want is not doable. Link to comment Share on other sites More sharing options...
Geyatautsilvsgi Posted August 23, 2018 Author Share Posted August 23, 2018 Thanks guys. Chop saw, I figured as much.It will require a twist and some serious cutting, even then I doubt it would have really worked well. I wanted to double check before I told them and faced the "what do you mean I can't do it this way" look,. It's nice to know every once in a while that I am not totally off. Thanks!!! Link to comment Share on other sites More sharing options...
AvoyeDesign Posted August 24, 2018 Share Posted August 24, 2018 5 hours ago, serenity said: "what do you mean I can't do it this way" "I'm the client, and when I say I want a round room that is square, I expect it!" Link to comment Share on other sites More sharing options...
Geyatautsilvsgi Posted August 24, 2018 Author Share Posted August 24, 2018 Yeah.....uh...huh... Link to comment Share on other sites More sharing options...
