conwaynorth1 Posted August 12, 2018 Share Posted August 12, 2018 Why doe the right wall snap back when I drag the front wall over to meet it? Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 12, 2018 Share Posted August 12, 2018 Break the right wall about the center of the left wall. Click the small, lower wall on the right one and reverse it on the edit button so CA thinks it is a different wall. Then drag the left wall over; it should stick. 1 Link to comment Share on other sites More sharing options...
JJohnson Posted August 12, 2018 Share Posted August 12, 2018 27 minutes ago, conwaynorth1 said: Why doe the right wall snap back when I drag the front wall over to meet it? Possibly just turn off object snaps ? Otherwise you should be able to drag the right wall back out to its desired length. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 12, 2018 Share Posted August 12, 2018 I think it may have something to do with minimum wall lengths. CA has always been finicky to me in this area. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 12, 2018 Share Posted August 12, 2018 55 minutes ago, conwaynorth1 said: Why doe the right wall snap back when I drag the front wall over to meet it? This tends to happen if the Wall extends less than it's own width past the intersecting wall in my experience ( CA is sometimes too smart for it's own good ) and as Mike said the easy fix is to Break The Wall and reverse the short section. Also, it's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too .............. See mine below in Blue for how to do that. If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on by going to the Upper RH Corner of this Forum Window and Clicking on your Username and making sure Signature are enabled (green) and then Add your Own Sig. too : UserName> Account > Signatures M. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted August 12, 2018 Share Posted August 12, 2018 27 minutes ago, Ridge_Runner said: Break the right wall about the center of the left wall. Click the small, lower wall on the right one and reverse it on the edit button so CA thinks it is a different wall. Then drag the left wall over; it should stick. This should do it. Link to comment Share on other sites More sharing options...
JJohnson Posted August 13, 2018 Share Posted August 13, 2018 4 hours ago, Kbird1 said: This tends to happen if the Wall extends less than it's own width past the intersecting wall in my experience ( CA is sometimes too smart for it's own good ) and as Mike said the easy fix is to Break The Wall and reverse the short section. That' what I think now that I saw this in the help files under CONNECTING WALLS When walls are drawn sufficiently close to one another, they will snap together to form an intersection. This snapping occurs when the walls’ center lines are within a distance defined by the larger of the two walls’ widths and will occur even when Object Snaps are turned off. See Object Snaps. Link to comment Share on other sites More sharing options...
