EconBlueprints Posted July 9, 2018 Share Posted July 9, 2018 When building decks attached to the house, the default (seems to be) for the deck ledger attachment to default to the exterior of the stud framing . I need to dimension the deck ledger to the exterior of the wall sheathing, as this is where it acutally attaches to the building exterior. However, I cannot automatically or manually pull the dimension string to snap to the exterior side of the sheathing layer. What setting do I need to change in order to accomplish this? Thanks, Lane Link to comment Share on other sites More sharing options...
rlackore Posted July 9, 2018 Share Posted July 9, 2018 AFAIK you can't snap to sheathing. Use a Point-to-Point dimension snapped to the framing, then manually grab the dimension marker and move it to align with the sheathing. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 9, 2018 Share Posted July 9, 2018 Also remember to turn off auto deck framing when modifying a deck already built or it will change back. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 11, 2018 Share Posted July 11, 2018 On 7/9/2018 at 1:54 PM, solver said: What dimension are you trying to show? If the ledger is against the sheathing ... Maybe an image would make this more clear. Expand I think he is referring to the fact that CA cuts the sheathing and Siding out around the Deck Ledger and butts it up to the Rim Joist , I have seen this with Wall ledgers too when doing Roof Framing. A point to Point dim should still work though , after moving the Deck ledger out in Elevation of course....... Link to comment Share on other sites More sharing options...
NRST8TRKR Posted July 11, 2018 Share Posted July 11, 2018 When you define your wall type if you set to dimension to exterior layer, choose OSB.This is the way I do it all the time. Also my deck band builds to the OSB layer as it should. Hope this helps,Ken 1 Link to comment Share on other sites More sharing options...
rlackore Posted July 11, 2018 Share Posted July 11, 2018 On 7/11/2018 at 5:42 PM, NRST8TRKR said: When you define your wall type if you set to dimension to exterior layer, choose OSB Expand Thanks for reminding me of this - I'd forgotten about this feature. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted July 11, 2018 Share Posted July 11, 2018 You are Welcome Have a great day,Ken Link to comment Share on other sites More sharing options...
