Dimension to sheathing layer
EconBlueprints
When building decks attached to the house, the default (seems to be) for the deck ledger attachment to default to the exterior of the stud framing .  I need to dimension the deck ledger to the exterior of the wall sheathing, as this is where it acutally attaches to the building exterior.
However, I cannot automatically or manually pull the dimension string to snap to the exterior side of the sheathing layer.    What setting do I need to change in order to accomplish this?
Thanks,
Lane
On 7/9/2018 at 6:54 AM, solver said:
What dimension are you trying to show? If the ledger is against the sheathing ...
Maybe an image would make this more clear.
I think he is referring to the fact that CA cuts the sheathing and Siding out around the Deck Ledger and butts it up to the Rim Joist , I have seen this with Wall ledgers too when doing Roof Framing.
A point to Point dim should still work though , after moving the Deck ledger out in Elevation of course.......
