pintodesign Posted June 25, 2018 Share Posted June 25, 2018 Hi all Somewhere along the line recently I lost my Chief X10 texture files. Any ideas on how to retrieve them? Thanks Barb Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 25, 2018 Share Posted June 25, 2018 If you can still find them, copy them to your X10 data folder (in the textures file) so you know where they are. You might also check in the X9 data folder for them. Where did you previously keep them? Only you know where. Link to comment Share on other sites More sharing options...
pintodesign Posted June 25, 2018 Author Share Posted June 25, 2018 Hi Perry The funny thing is, everything was installed in the default locations and was fine prior to some kind of "clean up" (I think) happened. I'm only missing the new stuff from X10. The old textures as well as bonus stuff is all there. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 25, 2018 Share Posted June 25, 2018 Tech support should be able to provide a replacement file or maybe even a library update would rebuild it. However I see one custom one there so I might be good to look for them on a backup. Link to comment Share on other sites More sharing options...
VHampton Posted June 26, 2018 Share Posted June 26, 2018 In the interim, you could do a back of an entire plan file from an older project. Save it to a folder from which you could pick and choose textures from. By way of example, any texture that I take off of Google gets copied and pasted into this file, where I'm able to pick and choose textures which are often "out of the box". Link to comment Share on other sites More sharing options...
pintodesign Posted June 27, 2018 Author Share Posted June 27, 2018 I tried a clean install and it's still not finding the files. Interesting that it's not finding Chiefs own "CoreCatalogsFiles.zip" and the location is in the default setting. I'll check with tech support as soon as I get a chance. Thanks for the help! Barb Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 27, 2018 Share Posted June 27, 2018 if you did a clean install then maybe you need to download core lib. again. Link to comment Share on other sites More sharing options...
