SketchB Posted May 4, 2018 Share Posted May 4, 2018 The walls on the 3rd floor of the attached file are the same as the other floors, why arent the front windows on that level see-thru? Link to comment Share on other sites More sharing options...
SketchB Posted May 4, 2018 Author Share Posted May 4, 2018 X9. File attached failed 3x Link to comment Share on other sites More sharing options...
SketchB Posted May 4, 2018 Author Share Posted May 4, 2018 Upload fails (file sz 5.2mb) Link to comment Share on other sites More sharing options...
Chopsaw Posted May 4, 2018 Share Posted May 4, 2018 Make sure the file is closed in Chief before uploading. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 4, 2018 Share Posted May 4, 2018 Here's my guess...That top wall is out of alignment and the wall below is building through to the roof above. Link to comment Share on other sites More sharing options...
SketchB Posted May 4, 2018 Author Share Posted May 4, 2018 See attached now. ty Admin2.plan Link to comment Share on other sites More sharing options...
DavidJames Posted May 4, 2018 Share Posted May 4, 2018 All of your windows are placed on level 1... If you draw them on their correct levels, everything seems to work out just fine. Link to comment Share on other sites More sharing options...
lbuttery Posted May 4, 2018 Share Posted May 4, 2018 most clients don't like to see clear windows very distracting to be viewing renders or rays and seem "junk" inside set the windows to opaque or assign a dull gray to the glass Lew Link to comment Share on other sites More sharing options...
SketchB Posted May 4, 2018 Author Share Posted May 4, 2018 The Windows are curtain windows, is there any other way doing it other than everything on the first level? Link to comment Share on other sites More sharing options...
SketchB Posted May 6, 2018 Author Share Posted May 6, 2018 Is there a way that i can open the file sent with Premier X9, without needing to upgrade now? Link to comment Share on other sites More sharing options...
SketchB Posted May 6, 2018 Author Share Posted May 6, 2018 Great idea. Thanks Link to comment Share on other sites More sharing options...
SketchB Posted May 6, 2018 Author Share Posted May 6, 2018 Got it. Thanks for your help Link to comment Share on other sites More sharing options...
