scout1 Posted May 2, 2018 Share Posted May 2, 2018 am I missing something I have imported dwg into new drawing created terrain with no result other than it turning out flat using x9 ACAD-15-450_TPO-1.DWGFetching info... Link to comment Share on other sites More sharing options...
Canuck Posted May 2, 2018 Share Posted May 2, 2018 Video 1056 in the video library. https://www.chiefarchitect.com/videos/watch/1056/import-a-surveyor-dwg-file-for-a-site-plan-or-terrain-perimeter.html I had to do a few of them to understand the importance of the steps they give. Link to comment Share on other sites More sharing options...
scout1 Posted May 2, 2018 Author Share Posted May 2, 2018 On 5/2/2018 at 9:06 PM, scout1 said: am I missing something I have imported dwg into new drawing created terrain with no result other than it turning out flat using x9 ACAD-15-450_TPO-1.DWGFetching info... Expand I have tried all steps in video 1056 with same outcome flat terrain this is why I included dwg for help thanks. Link to comment Share on other sites More sharing options...
dshall Posted May 2, 2018 Share Posted May 2, 2018 I gave your plan a go and I could not get it to work. In fact, when I imported I found nothing. Link to comment Share on other sites More sharing options...
scout1 Posted May 3, 2018 Author Share Posted May 3, 2018 On 5/2/2018 at 11:57 PM, dshall said: I gave your plan a go and I could not get it to work. In fact, when I imported I found nothing. Expand thanks for the try. I do get info in new drawing can see lots of information will let me build terrain ect. just stays flat thanks again for the try. Link to comment Share on other sites More sharing options...
dshall Posted May 3, 2018 Share Posted May 3, 2018 When you import, before you actually import, do you identify all stuff on the maj an$ min contours as contours? i: going off memory in r3gards to termin9logy. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 3, 2018 Share Posted May 3, 2018 It looks like all the terrain contours must have been cad blocked together and may not even contain elevation data. You could unblock them and convert to elevation lines and assign your own elevations, but they are not really even labeled from what I can see so unless you know the site very well it would be difficult to be sure and get it right. I would get in touch with the surveyor and ask if he can unblock the contour lines and maybe it will import with the data or you could ignore the contour lines and enter all of the elevation points and let chief generate the contours but you again would have to know what the surveyors codes mean or it could turn into a mess in a hurry. Link to comment Share on other sites More sharing options...
scout1 Posted May 3, 2018 Author Share Posted May 3, 2018 On 5/3/2018 at 12:14 AM, dshall said: When you import, before you actually import, do you identify all stuff on the maj an$ min contours as contours? i: going off memory in r3gards to termin9logy. Expand after importing dwg I do need to explode cad block before I can select a contour line On 5/3/2018 at 12:33 AM, Chopsaw said: It looks like all the terrain contours must have been cad blocked together and may not even contain elevation data. You could unblock them and convert to elevation lines and assign your own elevations, but they are not really even labeled from what I can see so unless you know the site very well it would be difficult to be sure and get it right. I would get in touch with the surveyor and ask if he can unblock the contour lines and maybe it will import with the data or you could ignore the contour lines and enter all of the elevation points and let chief generate the contours but you again would have to know what the surveyors codes mean or it could turn into a mess in a hurry. Expand thanks I did notice everything was on a cad block I will contact survey company and try again Link to comment Share on other sites More sharing options...
Chopsaw Posted May 3, 2018 Share Posted May 3, 2018 It might even be possible that all 20 of the E-PT-.... layers contain elevation data. Hard to say for sure. Do you have a DWG viewer or PDF copy of the survey? There is a legend that may help you out a bit. Link to comment Share on other sites More sharing options...
dshall Posted May 3, 2018 Share Posted May 3, 2018 Please pardon the ignorance, I am always confused as to import at inch or feet. Is there a way to identify which units to use for importation ? 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 3, 2018 Share Posted May 3, 2018 Trial and Error maybe ? In this situation where there is nothing much to confirm with it would be handy to know. Any DWG experts out there ? Also why don't the scale and legend import ? Link to comment Share on other sites More sharing options...
tommy1 Posted May 3, 2018 Share Posted May 3, 2018 My rule of thumb so for is any dwg received from a surveyor will be in feet....everything else in inches. Link to comment Share on other sites More sharing options...
