dimension on screen changes
Lorenchief
I'm trying to figure out why I can sometimes click on a dimension on screen and type in the new dimension and other times not find where to click. Am I missing something? I can't find any clear answer in the user guides. Trying to pull a line can be really tedious while simply typing in a number is a sure thing.
I agree with Robert, in that one's level of zoom directly effects your video card's ability to differentiate between the numerous possible selections in an area. After all the software is merely a mechanical device, that does not "know" what you are trying to do from one moment to the next.
I would think an improvement might be to add the dimension in the editing screen at least. In that screen it would be a simple change like a window or door dimension rather than fiddling around with a line or trying to find a handle.
Hover over the dimension you want to change. If your pointer changes to a hand, you can click the dimension to open it and edit it. If it does not change, at least two conditions are possible:
1) the dimension is not connected to that object in a way that allows that dimension to be edited. Connecting the dimension to the object may allow you to edit the dimension.
2) you're zoomed out too far. When locating objects using temporary dimensions, at times you must zoom in to activate the hand cursor that allows you to edit the dimension.
Other conditions may also cause dimensions to not be editable, perhaps other users will say if there are.
    30693
    mikedanderton
    mikedanderton
  • Similar Content
    • By Ange822
      Good morning, would anyone know how to show the dimensions text horizontally and not parallel to where the dimensions is being taken?
      I am tried looking in preferences / setting / other chief talks with no luck.
      Much appreciated!
    • By EMBARC
      Hi all! I have recently upgraded from X11 to X13 and have found a wee niggle when showing dimensions. Previously, I could show an internal dimension with the markers indicating the outer wall as a reference (to ensure the reader that the dimension is internal). When I click the dimension line they appear, but when I click off they disappear.
      Anyone know how to fix this? Thanks!
    • By HannaForestAsh
      When I place a window/door/etc. on a wall and type in the dimensions, sometimes it will move the edge of the wall instead of moving the window along the wall. (ie: if I have a 20' wall with a window on it, I want the length between the corner and the window to be 4'... instead of moving the window over on the wall, it will just extend the edge of the wall out past its original point so it's now 24'). Please help!! I'm not sure how to look up this issue so if there's a video on it already please direct me there!
    • By mattradk
      I am using CAX6 and am trying to get the exterior dimensions of a residential structure to reach to the extent just under the siding. From inside to outside, the exterior wall should have 1/2" wallboard, 2x6 stud walls, 1/2" OSB, 2" rigid insulation, and then siding for which I've allowed 1/2". All of the wall components will sit on the platform except for the siding, which should cover the rim joists.
      I believe I have the correct dialog box and selections to do it (or maybe not …. see attached screen shot). However, after I make the selections in the Wall Type Definitions dialog box and back out of the dialog boxes leading there, I find that the cross section is incorrect, and the outside of the siding is flush with the platform. If I return to the Wall Type Definitions dialog box to find out why, I find that my selections have not been saved.
      I'm careful to make sure that I back out of each dialog box correctly (Clicking OK, OK, Done, etc.) but the changes I make are not saved.
      There's probably something I need to select or conditions I have to meet, but darned if I can figure them out after hours of messing with it.
      Any thoughts on what I'm doing wrong?  Thanks!
    • By MichaelaS
      I have a railing that is currently being dimensioned to from the outside of the panel. I would like to transition that dimension to either the center of the post or the outside of the post. However, I am unable to manipulate the extension line itself to snap to the corner of the post.
