wjmdes Posted April 1, 2018 Share Posted April 1, 2018 When I did this section yesterday it worked fine. Today I raised the joists up for a suspended ceiling and the section now shows a lumber symbol. Have spent 3 hours trying to fix this with no answer. This is my biggest gripe with CA is when something goes wrong it seems entirely too much time is lost looking for a solution which ends up being something simple. 17-1018_KFTE_Road.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted April 1, 2018 Share Posted April 1, 2018 Not sure if this is the correct functionality or not but it seems that if the camera cuts the C channel it displays as a cross box in section view yet if the member is not cut it appears as a "C" . Any chance you move the camera ? Could not find a saved one. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 1, 2018 Share Posted April 1, 2018 1 hour ago, Chopsaw said: Not sure if this is the correct functionality or not but it seems that if the camera cuts the C channel it displays as a cross box in section view yet if the member is not cut it appears as a "C" . Any chance you move the camera ? Could not find a saved one. I think Chopsaw might be right about , if the section cuts the joist or not, as it seems if CA thinks it is a Joist it gives the white cross box for most material types except I Beam and I joist which are correct. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 1, 2018 Share Posted April 1, 2018 Seems to be the same behaviour in X9. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 1, 2018 Share Posted April 1, 2018 I think it is now confirmed to be unwanted graphic behavior, time to turn this in as a "Bug Report" and get it fixed for all of us. DJP Link to comment Share on other sites More sharing options...
wjmdes Posted April 1, 2018 Author Share Posted April 1, 2018 10 hours ago, Chopsaw said: Not sure if this is the correct functionality or not but it seems that if the camera cuts the C channel it displays as a cross box in section view yet if the member is not cut it appears as a "C" . Any chance you move the camera ? Could not find a saved one. I went back in this morning and looked at them from the end, not a cross section and they were "C"'s. So it appears CA is messing it up. Where do I go to report the error or has some one already done that? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 1, 2018 Share Posted April 1, 2018 https://www.chiefarchitect.com/support/#contact DJP Link to comment Share on other sites More sharing options...
wjmdes Posted April 3, 2018 Author Share Posted April 3, 2018 - Support Answer - Anne Smith Tuesday, Apr 03, 2018 - 03:14 PM PDT Hello William, Thank you for contacting us regarding the profile of C and U Channel framing in clipped section views and for sending us an example. I will report this issue to our Software Development team and thank you for bringing it to our attention. Link to comment Share on other sites More sharing options...
RodCole Posted April 3, 2018 Share Posted April 3, 2018 There is another issue I have found with C channel behavior in Chief when using mirror copy. I kept intending to report this, but I don't actually remember doing it. I have not been involved in a project using C channel for a while now, but from what I remember Chief was not doing a transform of the actual C shape, but just the basic box of the profile. As in, it will mirror copy the Channel, but it does not actually flip the Channel as one would expect from a true transform matrix of the actual shape. This would probably be a good time for others to verify this behavior. Who knows, they may have fixed it by now. BTW on large projects that make use of similar room and therefore floor beam arrangements, having this work properly would be a real time saver. I will try to check this out again as well. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 4, 2018 Share Posted April 4, 2018 I sent in a fairly comprehensive report in early 2017 on this issue and there have been some improvements but not sure I would consider it a fix. To be fair I should redraw the test plan from scratch in X10 but here is what happened when I brought the plan forward. Maybe a little feedback from others who use this all the time would encourage them to take another look at the issues. Link to comment Share on other sites More sharing options...
