Displaying Deck Rails
IsaacStanfield
I finally figured out how to modify the stock rails, but I can't figure out how to output the drawing in anything other than plan view. The guy who will be making the railing needs to see it with dimensions. I just need a drawing of the railing by itself without a building, room, etc. It's probably an obvious solution but I don't know it yet. I'm using X10 on a windows machine.
Draw the Railing in it's Own Plan perhaps or use a BackClipped Cross Section set to 6" so you only see the Railing might work too
Post the Plan and I think someone will advise...
this is a User Based self help Forum so as others said it's good to have your Forum Signature filled in please,
especially with the Software Version, and of course a Name is nice too :) ..............
***see mine below in Blue for how to do that.
If you don't see my Signature then you have them turned off for the Forum
Toggle it on in UserName>Account >Signatures...... go to the Upper RH Corner of Forum Window.
Thanks for the responses. I guess I should have more clear. The only thing I've drawn is the railing. I need to make elevations of different sections to give to the welder. The plan I'm working in has no building, no deck, nothing except sections of railing. I'll try the back-clip thing. I've only been using CA for about a month so I'm still finding my way around.
I tried to turn on signatures but my browser is resisting. It seems like the forum culture has a thing for sigs. For everyone's information, I'm using X10 on a Windows computer.
Thanks for the tip Kbird1. My username is my name. Did I do that wrong too?
If all you have is the railing it should be very simple to take an elevation view of it and add dimensions and notes as needed.
This assumes that you have the railing designed as you want in the first place.
Regarding the signature...it not only helps all of us understand the version and equipment you are using but also demonstrates a level of commitment on your end ;)
I finally found the elevation maker. It took me forever. Now I'm wrestling with where the dimensions snap to and how to get it to dimension the balusters along with total width.
I see your point about the sig. I've never used them on other forums so it's a new concept for me. I try to be respectful of forum cultures wherever I go but honestly, other than my equipment I'm just not that interesting.
Not at all Isaac  :) but most people Don't use their Real names as there UserName and personally if I am helping someone I prefer to respond to someone by name ... not "something" on the internet , we are after all a User Community helping each other here .... not paid Support Staff. I'd still suggest putting Isaac in the Signature for your Future Posts which I assume will be many over the coming years....
The biggest reason though is there are many versions of Chief going back 20yrs ( and the Home Designer titles) and if you aren't using the latest there are often quite different Answers as we get new tools every version.
    30693
    mikedanderton
    mikedanderton
  • Similar Content
    • By ericepv
      Floor plans and renderings from a Rochester, NY based company available for remote work. I am a long time Chief user (X6 to X13) and have worked for many commercial and residential clients across North America. You can view samples of my work on my website, Houzz profile  or my YouTube channel.
      Please contact me directly at 585-441-5291 EST or by email: eric@epvisualz.com.
    • By j2narchitecture
      I am using the railing to auto generate columns and beam for an exterior porch.
      For some reason, the railing is generating 4 -1/2 columns, where only 3 are needed.
      The spacing is set to 8' o.c. for the columns.
      How can I correct this so that only 3 columns are being generated?
      Any feedback is appreciated.
      See attached plan file and circled area on the pics.
      TIA
      PLAN FILE
    • By DeLayDesign
      I've set up our walls to show demo'd walls to be dashed, but I'd also like that dashed line to show up in elevation as well.  Is there a way to do this, without moving the wall to a 'demo wall layer'.
      I suppose I could edit all the walls so that anything that isn't to be demo'd isn't associated with the layer it's put on (remaining solid vs. dashed); but is there a better way?
      I would also love for the siding/ brick, etc. to come in dashed as well if possible.
    • By DeLayDesign
      My client has a very specific look in mind, "H" shaped columns.  I've managed to create them as a 3D item and import them as a column; however, when placed they all seem to act as I want them to, except one.  What's the solution to this without having to place them all manually?
      TIA.
      Adam
    • By Mardie
      Of Course on a deadline and never experienced this in 20 years!  HELP!  See attached.  Working on elevations.  Using exactly the same cross section elevation, but one is coming up as "Active Defaults" and one is coming up as "1/4" Defaults", there is not an option for "Active Defaults" in the drop down.  Creating havoc on Notes.  Have not idea how to fix this.  Thanks!  Mardie
