SNestor Posted March 23, 2018 Share Posted March 23, 2018 Is there a way to control the number of trimmers created at stair openings. In the pic below...the software has placed a double trimmer at the stair opening on both sides...but, on one side there is actually a load bearing wall and only a single trimmer is required so that the joists can bear on the wall. Is there someplace in the software that controls this? Thanks. Link to comment Share on other sites More sharing options...
GeneDavis Posted March 23, 2018 Share Posted March 23, 2018 You, your mouse, and Chief"s excellent framing edit tools. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 24, 2018 Share Posted March 24, 2018 I usually need a beam for those so just draw a ceiling beam 1 Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted March 24, 2018 Share Posted March 24, 2018 I set the o.c. spacing to 96" (can't set it any higher), autobuild joists / sills then delete all joists (hence the few as possible in autobuild) except stair openings and rimboard. Then I set all joist in correct location and quantity. In your case I would just select joist and replicate / move 1.5".....done! Link to comment Share on other sites More sharing options...
SNestor Posted March 25, 2018 Author Share Posted March 25, 2018 Ok...so the answer is no. Manual edit is required. Auto building floors then almost always will require “time” to make fixes. Thanks all for your comments and expertise. Link to comment Share on other sites More sharing options...
