WoodlandDesign Posted March 5, 2018 Share Posted March 5, 2018 I have placed a double bin Rev-A-Shelf drawer in a cabinet. Everything worked fine but I am unable to get the bins to display in plan view. The plan view just shows a cabinet with counter top and doesn't include bin outline. Is it an option to do so? If so, what do I need to do to achieve? I don't want just a label on the cabinet. I want it to show the outline of the bins to simplify the plans for my client. I can place a Re-A-Shelf item in or on the cabinet without incorporating into the drawer specs but that only looks good for plan views but isn't the correct way. I also don't want redundancy of having two sets of bins in a cabinet. Thanks in advance. Chief Architect Signature.docx Link to comment Share on other sites More sharing options...
Kbird1 Posted March 5, 2018 Share Posted March 5, 2018 In the Defaults>Cabinets>General there is an Display option to Show Doors and Drawers which should work I think...not sure if it shows REV. Catalog items too as I haven't tried it... Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 5, 2018 Author Share Posted March 5, 2018 I played with that but it only shows an outline of a single rectangle representing a general drawer box and not a double waste basket outline unfortunately. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 5, 2018 Share Posted March 5, 2018 how was the rev-a-shelf waste basket put into the cabinet? Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 5, 2018 Author Share Posted March 5, 2018 I created a drawer then went into the drawer specification DBX and called out the Rev-A-Shelf item from the library. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 5, 2018 Share Posted March 5, 2018 okay I tried a Waste basket and a Drawer Insert and they only show if I drag them into a Cabinet ..... still playing ..you need to set the height off the floor that way though. M. Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 5, 2018 Author Share Posted March 5, 2018 Yep. I did that also but it isn't really making the component part of the cabinet. It's just setting it inside the cabinet box. It can't be operated like a drawer or door as it should. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 5, 2018 Share Posted March 5, 2018 You can use 1 of each as a workaround but @McMark Mark is the Cabinets Expert here, he may know how to do it. M. Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 5, 2018 Author Share Posted March 5, 2018 I thought the same but don't want to deal with the mess it creates; Double components in each cabinets would be hard for me to remember and difficult to explain to clients. Thanks for your input though Mick. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 5, 2018 Share Posted March 5, 2018 You can't see one when you see the other depending on the View ? or are you showing open in 3D and closed in Plan View? M> Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 5, 2018 Author Share Posted March 5, 2018 In 3D view the two separate trash/recycling bins are present. In plan view, only the placed bin shows. It seems one serves a purpose and the other another purpose. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 5, 2018 Share Posted March 5, 2018 Yes , same thought here.....if you put the Placed one's on a separate layer , you can turn them off in 3D Views though. M. Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 5, 2018 Author Share Posted March 5, 2018 That's true. Good suggestion. Just seems like the component should be viewable in plan view after placing into the cabinet like an appliance is. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 5, 2018 Share Posted March 5, 2018 Rev-Shelf was originally a Sketch-Up Library , so I don't think it has all the Capabilities of the Chief In-House Symbols , some of the Items are all one material even , ie even the Drawer Slides and Utensils are Wood in some etc Link to comment Share on other sites More sharing options...
MarkMc Posted March 5, 2018 Share Posted March 5, 2018 43 minutes ago, Kbird1 said: You can use 1 of each as a workaround but @McMark Mark is the Cabinets Expert here, he may know how to do it. M. Nice of you to say Mick. I believe the problem is that for say a trash pullout, Chief thinks it's a drawer. If it was something I really wanted I'd get the CAD block and insert it. Since that can't be blocked to the cabinet I'd be doing that only in finals. I don't show them nor do I want to. (I don't even like that drawer boxes show if I want to show doors). Even back when I floated these things on different layers to fake opening I hid them in plan. There is enough going on in a kitchen plan and just about nobody that matters (client, installer, even maker) knows what these look like in plan. I want them in the schedule so I can order properly, in the correct size cabinet, opening is "nice" since the clients like it. OTOH besides including correct labeling or codes for special inserts in whatever field I'm using for Mods I also note any inserts or accessories in plain English in the Comment field. Then include one separate plan with referenced macros, %Comment%, plain English that the client and installer can understand it. I save the ones I use in the library with a note to self for minimum maximum width. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 5, 2018 Share Posted March 5, 2018 I had not thought about inserting the CAD Block, from the Symbol, if needed , that would work if someone really wanted to shown it in Plan View and is easy to do , and you could hide them with a different Layer too in certain Views. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 5, 2018 Share Posted March 5, 2018 Link to comment Share on other sites More sharing options...
