Mono Slab Labeling - the easy way
Joe_Carrick
When Chief creates a Foundation Plan it names the areas as "Rooms" of the type directly above.  Obviously, this is non-sense so I created a new Room Type (copy of Slab) which I named:
  • 4" Concrete Slab
Then I edited all the foundation areas to that room type.
Then I added the attached macro room_label.json to the Default Room Label.
Now those areas of the Foundaton Plan are automatically labeled:
           4" Concrete Slab
         with 6/6 10/10 WWF
   over 6 mil Visqueen Membrane
           over 4" Sand Base
The macro recognizes the room is a Slab.
Of course that's what I use for a Mono-Slab Foundation.
For Built-up Foundations I just use a Room Type:
  • Crawl Space
