Joe_Carrick Posted February 28, 2018 Share Posted February 28, 2018 When Chief creates a Foundation Plan it names the areas as "Rooms" of the type directly above. Obviously, this is non-sense so I created a new Room Type (copy of Slab) which I named: 4" Concrete Slab Then I edited all the foundation areas to that room type. Then I added the attached macro room_label.json to the Default Room Label. Now those areas of the Foundaton Plan are automatically labeled: 4" Concrete Slab with 6/6 10/10 WWF over 6 mil Visqueen Membrane over 4" Sand Base The macro recognizes the room is a Slab. Of course that's what I use for a Mono-Slab Foundation. For Built-up Foundations I just use a Room Type: Crawl Space Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 28, 2018 Share Posted February 28, 2018 Yes, I'm always fixing those slab room labels, It takes time to do it especially if you have lots of interior footings, lots of rooms to fix, so I set the interior room footings as no definition Link to comment Share on other sites More sharing options...
Kbird1 Posted February 28, 2018 Share Posted February 28, 2018 Thanks for the Tip and the Macro Joe , I appreciate it. Mick. Link to comment Share on other sites More sharing options...
