Haskellf Posted February 26, 2018 Share Posted February 26, 2018 In South Florida, homes are prominently constructed out of concrete blocks, metal studs & beams, concrete headers/lentils/beams, and wooden trusses. Which software would you recommend that would be best suited for concrete home construction? Also, I can't find any training videos for CA that uses concrete blocks and therefore I wanted to ask you all if you know of any videos or tutorials for CA... Or maybe one of the aforementioned software would be better suited for concrete block construction? 1 Link to comment Share on other sites More sharing options...
lbuttery Posted February 26, 2018 Share Posted February 26, 2018 Hi: while waiting for responses, you could also contact CA's customer service and discuss with them they are very friendly and helpful Lew Link to comment Share on other sites More sharing options...
johnny Posted February 26, 2018 Share Posted February 26, 2018 57 minutes ago, Haskellf said: In South Florida, homes are prominently constructed out of concrete blocks, metal studs & beams, concrete headers/lentils/beams, and wooden trusses. Which software would you recommend that would be best suited for concrete home construction? Also, I can't find any training videos for CA that uses concrete blocks and therefore I wanted to ask you all if you know of any videos or tutorials for CA... Or maybe one of the aforementioned software would be better suited for concrete block construction? I work with Florida builders and developers who use this type of construction and everything works fine. However, I am not doing full 3D workups of exact replication of construction methods...i do more a hybrid with 2D details to support. If that is acceptable I think Chief works great. If you want full BIM for this type of construction then Chief may not be the best choice. Though, of your list of other software choices I don't think there is an ideal solution outside perhaps Revit - but I personally dislike that app. If you need to model these buildings completely id look into Archicad, Vectorworks, and Allplan. That said, I do think Chief could work for you. Link to comment Share on other sites More sharing options...
ChiefGrego Posted February 27, 2018 Share Posted February 27, 2018 I'm Relatively inexperienced but would think you would could use same materials but defined slightly different texture or properties, say as concrete rather than wood. This is not new to Chief I am sure. Find the tutorials on creating your own concrete lintels, Wall, ect. Search google for "chief Architect concrete lintels for example. I'm really surprised some of these guru's have not responded to this post as these guy's can do just about anything. Link to comment Share on other sites More sharing options...
dshall Posted February 27, 2018 Share Posted February 27, 2018 22 hours ago, johnny said: I work with Florida builders and developers who use this type of construction and everything works fine. However, I am not doing full 3D workups of exact replication of construction methods...i do more a hybrid with 2D details to support. If that is acceptable I think Chief works great. If you want full BIM for this type of construction then Chief may not be the best choice. Though, of your list of other software choices I don't think there is an ideal solution outside perhaps Revit - but I personally dislike that app. If you need to model these buildings completely id look into Archicad, Vectorworks, and Allplan. That said, I do think Chief could work for you. JPC probably knows the pluses and minuses of the different programs as well as anybody. The fact you are having to ask the question leads me to believe that BIM is not a priority for you. My bet is CA is your best choice. 1 Link to comment Share on other sites More sharing options...
rlackore Posted February 27, 2018 Share Posted February 27, 2018 I think Chief will work fine. Important things: 1) Set up your wall definitions appropriately. I don't know what kind of insulation values you need in Florida, but here's an exterior wall with exterior continuous insulation, filled CMU cores, and interior steel stud furring: Interior walls can also be defined to use steel stud sizes and materials. 2) Do you use slabs-on-grade for residential in Florida? If so, set up your foundation defaults appropriately: 3) Define your room structure for CMU nominal wall heights and a slab foundation: 4) Set up your framing defaults, such as floor and roof beams: 5) Set your lower story exterior walls to hang the floor framing: These very basic settings can start to get you there: There are lots of other settings to tweak, but these are some of the basics. Then draw the house using a standard Chief workflow and you'll discover what else needs to be done. And as Johnny mentioned, you'll always need to utilize some workarounds and CAD details, just like stick framed homes. 1 Link to comment Share on other sites More sharing options...
Potential_Custmr Posted August 27, 2018 Share Posted August 27, 2018 Thnak you for asking this question as it helps me with mine as well. Link to comment Share on other sites More sharing options...
Robert_N Posted October 9, 2018 Share Posted October 9, 2018 Very helpful question and posts!!! Thanks everyone! Link to comment Share on other sites More sharing options...
