Kbird1 Posted March 12, 2018 Share Posted March 12, 2018 On 2/26/2018 at 8:18 PM, ACADuser said: Not that simple I'm afraid. That is why I recommended printing to a PDF & use that to import. @ACADuser It would be best for Alan to answer you as I don't know what He did for you or what it is you need...He is familiar with both. Model Space and PaperSpace is the most common issue when exporting from ACAD I am not really a big ACAD User ......I bought Chief cos I didn't like it Link to comment Share on other sites More sharing options...
RL-inc Posted March 12, 2018 Author Share Posted March 12, 2018 Thanks Mick- as you mentioned in #20 can I export the view and it's layers shown from Draftsight? How? Link to comment Share on other sites More sharing options...
ACADuser Posted March 12, 2018 Share Posted March 12, 2018 https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Core/files/GUID-653D3843-AFE5-4569-959F-E06F3866D7D7-htm.html The first statement in this link is not true. You can export all visible objects from the current layout to model space in a new drawing. As you read further you will see all the objects that will not be exported. Your sample drawing is a somewhat complex case. There are block within blocks and the EXPORTLAYOUT command can not unbundle the nested objects to get the export you want. To make matters worse the 2nd DWG file is being referenced into the main DWG. Link to comment Share on other sites More sharing options...
RL-inc Posted March 12, 2018 Author Share Posted March 12, 2018 Thanks for all the efforts in trying to educated me- Can I ask one time - please just try and import the attached DWG into CA and tell me if you get a proper view. When I do it I get absolutely nothing. I sent this file to an AutoCAD user and he open it and shows floor plan. A1.11 SECOND FLOOR PLAN.dwg Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 12, 2018 Share Posted March 12, 2018 I opened up your file in Draftsight myself a while back and I didn’t respond because there really wasn’t an easy answer and it seemed Alan’s conversion to PDF was probably the best solution. I guess the only thing I might add is this... You could try to export from Draftsight to PDF and then use one of the many online PDF converters to convert your PDF to DWG. Worth a shot anyway. If I was you though I might just redraw from scratch using the PDF and/or DWG as a guide. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 12, 2018 Share Posted March 12, 2018 3 minutes ago, RL-inc said: Thanks for all the efforts in trying to educated me- Can I ask one time - please just try and import the attached DWG into CA and tell me if you get a proper view. When I do it I get absolutely nothing. I sent this file to an AutoCAD user and he open it and shows floor plan. A1.11 SECOND FLOOR PLAN.dwg I had tried opening your original files a while back and was able to open it n Chief without any problems per se, but there was also a lot of missing information that i could see in Draftsight and not in Chief. Link to comment Share on other sites More sharing options...
ACADuser Posted March 12, 2018 Share Posted March 12, 2018 The second floor dwg file is missing the needed xref file. Link to comment Share on other sites More sharing options...
