postandbeam Posted February 6, 2018 Share Posted February 6, 2018 My roof soffits are "floating" below my facia by a few inches (flat soffit, plumb cut rafters). I have a steep roof pitch with tall rafters, and it appears that the soffit is automatically placed under the theoretical point of the bottom of a plumb cut rafter. I would like the soffit to be higher up (in the field, I would trim the point (bottom triangle) off the rafter so that the facia isn't very tall. Is there a way to do that in Chief X9? There is an attached image of my Chief generated section and a 3D view of how the soffit currently shows. Thanks Link to comment Share on other sites More sharing options...
Chopsaw Posted February 6, 2018 Share Posted February 6, 2018 As Eric says the soffit will trim to the bottom of the sub fascia but you will need to have "Trim Framing To Soffits" selected in the Roof Plane DBX under the Structure tab. Link to comment Share on other sites More sharing options...
postandbeam Posted February 6, 2018 Author Share Posted February 6, 2018 Unfortunately, that doesn't move the soffit, it just moves the facia... I attached the result: Link to comment Share on other sites More sharing options...
postandbeam Posted February 6, 2018 Author Share Posted February 6, 2018 I responded before seeing Chopsaw's note. The option to "Trim Framing To Soffits" is greyed out. I poked around trying to see if I could make other selections that would enable the checkbox, but haven't been successful, any recommendations of what to try? (image of my DBX attached) Link to comment Share on other sites More sharing options...
Kbird1 Posted February 6, 2018 Share Posted February 6, 2018 Post (attach) the Plan file while it is closed in CA and someone will figure it out for you.... Also, it's good to have your Forum Signature filled in please, especially with the Software Version, and of course a Name is nice too ..............see mine below in Blue for how to do that. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2018 Share Posted February 6, 2018 You should really post the plan. Otherwise we could sit here guessing at things all day long. Link to comment Share on other sites More sharing options...
justmejerry Posted February 6, 2018 Share Posted February 6, 2018 Try setting it in the Defaults not as you build it. I have both in the roof defaults and framing defaults checked and it works. Link to comment Share on other sites More sharing options...
postandbeam Posted February 6, 2018 Author Share Posted February 6, 2018 The plan is attached here. The option to "Trim Framing To Soffits" is greyed out, and I can't figure out how to enable it. Test Plan For Beam Roof System.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2018 Share Posted February 6, 2018 I'll make you a quick video...Please hold Link to comment Share on other sites More sharing options...
justmejerry Posted February 6, 2018 Share Posted February 6, 2018 Change the material that is framing to fir framing. Remove the things not fir framing and put that in the surface portion. You may want to adjust the sub fascia size, that's up to you. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2018 Share Posted February 6, 2018 Here's a quick video... 1 Link to comment Share on other sites More sharing options...
postandbeam Posted February 6, 2018 Author Share Posted February 6, 2018 Wow, not sure I understand the "Why?" justmejerry's note to change the material of my rafters from my own "Fir" material to built-in "Fir Framing" now allows me to "Trim Soffit To Framing" and the roof framing now builds (I posted a separate question about not being able to get framing to build." Why would a material choice change those things? Alaskan_Son- I can't get your video to play, but am working on it. Can't thank you all enough for the help... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2018 Share Posted February 6, 2018 4 minutes ago, postandbeam said: Alaskan_Son- I can't get your video to play, but am working on it. Can't thank you all enough for the help... Sorry, there was a problem during the upload process. Try it again. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2018 Share Posted February 6, 2018 5 minutes ago, postandbeam said: Why would a material choice change those things? Watch my video and you'll probably understand better but its not the material per se rather its the material TYPE as I mentioned over in that other thread. 1 Link to comment Share on other sites More sharing options...
postandbeam Posted February 6, 2018 Author Share Posted February 6, 2018 THANK YOU!!!! I learned a number of things: Signature line is important :-) Posting plans makes it easier (even if I'm embarrassed about my hack plans) Setting a material to be a Framing Material- fixed both my problems. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted February 7, 2018 Share Posted February 7, 2018 You can Frame with your own Materials , for example I made a Spruce Library for myself , you just need to make sure the Material Type is set to Framing. Also Note that if you do so, while the "Spruce" will show in the Framing Schedule , in the Materials List , (if you use?) it will still call it Fir. T.S.upport has told me this is because the ML has the FIR name Hard-coded into it and they currently don't plan to change that. PS in Micheal video overview it looked like your Roof Planes may not be joined Properly ...looked like something was sticking up... 1 Link to comment Share on other sites More sharing options...
