ACADuser Posted January 22, 2018 Share Posted January 22, 2018 Is there a way to remove the molding on the bottom of the door? Link to comment Share on other sites More sharing options...
ACADuser Posted January 22, 2018 Author Share Posted January 22, 2018 I posted the plan here: Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 22, 2018 Share Posted January 22, 2018 1 hour ago, ACADuser said: Is there a way to remove the molding on the bottom of the door? Alan, I find this happens sometimes when Windows and Doors are mulled together. Try making the windows on either side of the Door from non-opening doors. Link to comment Share on other sites More sharing options...
VisualDandD Posted January 22, 2018 Share Posted January 22, 2018 I still wish you could place a door header at proper height (83"), and not get a piece of molding applied to the bottom. "Standard" headers are 83" for 6-8 doors and the only way around this is the make the door taller and then use custom labels. Wish there was a definition for "door threshold" in the dbx so something this simple could me done right. 1 Link to comment Share on other sites More sharing options...
ACADuser Posted January 22, 2018 Author Share Posted January 22, 2018 Eric the exterior sill did fix that, Thank you. Joe I'll give that a try, although the customer wants Single hung. I guess I could fake a window. I'm sure the door would behave better. Link to comment Share on other sites More sharing options...
ACADuser Posted January 22, 2018 Author Share Posted January 22, 2018 Also the interior base molding does not respect the window. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 22, 2018 Share Posted January 22, 2018 18 minutes ago, ACADuser said: although the customer wants Single hung. Bad idea at that location. Link to comment Share on other sites More sharing options...
ACADuser Posted January 22, 2018 Author Share Posted January 22, 2018 Tell me about it. I have spent at least twice as long with this client talking her out of stuff. Link to comment Share on other sites More sharing options...
ACADuser Posted January 22, 2018 Author Share Posted January 22, 2018 That worked well Joe, Thanks. Link to comment Share on other sites More sharing options...
ACADuser Posted February 1, 2018 Author Share Posted February 1, 2018 How do you turn off the door open direction lines for just those doors in elevation view? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 2, 2018 Share Posted February 2, 2018 Turn Off Opening Indicators in the Camera View works.... but you'd lose them all ...is the sidelight a Door? you may need to make them from a full height window to just turn them off. Link to comment Share on other sites More sharing options...
ACADuser Posted February 2, 2018 Author Share Posted February 2, 2018 Thanks Mick I was afraid of that. Not the end of the world though. Link to comment Share on other sites More sharing options...
