gregtvillage Posted January 17, 2018 Share Posted January 17, 2018 My Brick hatching and outline have disappeared. Hatching is turned on and brick shows on all views. When I select the walls you can see the outline of a wider wall showing the brick is still there. Help! Greg Link to comment Share on other sites More sharing options...
Kbird1 Posted January 17, 2018 Share Posted January 17, 2018 Some images would help explain the problem ...use the Windows Snipping Tool Also please fill in your Signature ....see mine below for how to do that , thanks.... M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 17, 2018 Share Posted January 17, 2018 That is a common problem with Brick in that lots of brick patterns use white or whitish mortar and in vector views, white does not print (it IS there but invisible to the eye in vector view cameras). So what you do is to set the line color to Black for Vector View camera shots in the Define Materials Dialog and then it will show up and print in layout views sent to layout from a vector view camera. DJP Link to comment Share on other sites More sharing options...
gregtvillage Posted January 18, 2018 Author Share Posted January 18, 2018 The brick is only missing in the floor plan view? Thanks Greg Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 18, 2018 Share Posted January 18, 2018 In floor plan that pattern would be on a layer called "Rooms" DJP Link to comment Share on other sites More sharing options...
glennw Posted January 18, 2018 Share Posted January 18, 2018 Turn off the "Walls, Main Layer Only" layer. Link to comment Share on other sites More sharing options...
gregtvillage Posted January 18, 2018 Author Share Posted January 18, 2018 Thanks to all who tried. Turned off Walls,Main Layer and eureka brick appeared. So simple after much frustration. I'll dance at your next wedding. Greg Link to comment Share on other sites More sharing options...
Kbird1 Posted January 18, 2018 Share Posted January 18, 2018 always a good idea to post images , but for a quicker "fix" it is way better to post the plan file , so someone can just look for you.... - Nice catch GlennW Link to comment Share on other sites More sharing options...
glennw Posted January 19, 2018 Share Posted January 19, 2018 That one is a real sneaky one as it is illogical to have a setting like that. If you toggle all layers on, one would not expect for something to be toggled off. But it has been around for a long time now. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2018 Share Posted January 19, 2018 This just came up here too but if I have All On Set I see everything... Link to comment Share on other sites More sharing options...
