Designer1 Posted January 3, 2018 Share Posted January 3, 2018 Im working on some older Chief plans and am familiar with the text tool to add different information about your plan per each room label. However, I cant seem to be able to adjust items listed per room label. Since it was many versions of chief ago that created these, when I go into room labels its not showing them listing the square footages, plus room dimensions. Where can I go to adjust these if they arent showing up as being added to the labels? Thanks in advance! Link to comment Share on other sites More sharing options...
Kbird1 Posted January 3, 2018 Share Posted January 3, 2018 56 minutes ago, solver said: Just guessing because I don't follow I think that is right .....ie the old plans don't have the 3 Area/Room Sizes Displayed ( under Rooms), probably on in your new plans? Link to comment Share on other sites More sharing options...
Designer1 Posted January 3, 2018 Author Share Posted January 3, 2018 Yes, I can control the room label if I go in the dbx and uncheck room label. Im wondering how I can get it to display but not have all the square footage extras on there? I cant remember what version of Chief changed layers but I remember a learning curve going from the old standard of layers to the new. Now Im trying to get this old plan figured out in the new chief. Link to comment Share on other sites More sharing options...
glennw Posted January 3, 2018 Share Posted January 3, 2018 You are not explaining yourself very well. I will have a guess: Have you saved any text information or macros in your default Room Label defaults. Can you explain what you want the end result to be? Link to comment Share on other sites More sharing options...
Designer1 Posted January 3, 2018 Author Share Posted January 3, 2018 Hi Glen, what I want is the default room labels...room name and typical room size. Im not interested in the added square feet provided on the label right now. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 3, 2018 Share Posted January 3, 2018 10 hours ago, Designer1 said: Hi Glen, what I want is the default room labels...room name and typical room size. Im not interested in the added square feet provided on the label right now. Sounds like you need to turn Off the Rooms, Standard Area Display ......in the ALDO perhaps the Rooms,Interior Area too .....................not in the DBX > Label Tab. ie the opposite of what Eric and I thought you were trying to do initially..... see his Pic again above and uncheck the two options I just mentioned. Link to comment Share on other sites More sharing options...
Designer1 Posted January 4, 2018 Author Share Posted January 4, 2018 Thanks Mick and Eric. I havent ever had this much trouble with room labels in over ten years of using chief. Usually the standard info in room labels is fine. I see the picture Eric provided above. Where do I go to find all the check boxes that I want to include or exclude from the room labels that he is showing? Link to comment Share on other sites More sharing options...
Chopsaw Posted January 4, 2018 Share Posted January 4, 2018 Try looking in ALDO ( Active Layer Display Options ) the third one over from Preferences usually. ALDO is great because it will find all those layers for you just by selecting the room. Link to comment Share on other sites More sharing options...
Designer1 Posted January 4, 2018 Author Share Posted January 4, 2018 Nice, thank you Chopsaw! Link to comment Share on other sites More sharing options...
Designer1 Posted January 4, 2018 Author Share Posted January 4, 2018 Chopsaw, that was it...found it! I was laughing because I was counting three over from preferences but it wasnt it... then I remembered I had a custom toolbar on so when I switched to default tool bar it was right there...three over from preferences. So glad I found it! Thanks again for everyones help. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 4, 2018 Share Posted January 4, 2018 Glad you got it finally sorry I didn't think about the fact not everyone may use the ALDO frequently or be familiar with it, I always have it open for me as I use Dual Monitors, so pull it and the Library out to separate Windows. Thx. Chopsaw... Link to comment Share on other sites More sharing options...
Designer1 Posted January 6, 2018 Author Share Posted January 6, 2018 Mick, no problem! Theres no right way to use Chief and it sounds like with two monitors, your way of doing it is very efficient. I need to get the two monitors going! Thanks for all your help and suggestions Mick it was a learning experience so now I know more about this aspect of Chief. Link to comment Share on other sites More sharing options...
