Fence over Half Wall / Parapet
Muhammad_Habib
For a railing on top of a half-wall:
1. Draw the half-wall.
2. Draw the railing and make it No Room Definition and No Locate.
3. Align the railing with the half-wall, then adjust the railing heights as necessary so they are higher than the half wall.
57 minutes ago, Muhammad_Habib said:
Chief developers should make like Pony Wall solution, where upper wall can be made a railing.
I think I saw something in the X10 Trailer Video that might suggest they are already working on this concept.
2 hours ago, Muhammad_Habib said:
Thanks Robert.
I had done this 'trick', but here problem arises of continuous error of not connecting walls with the cursor. So, not a satisfactory way.
Habib
this has been asked for many times in the last few years , so hopefully in the next version it will be there......in the mean time , you can also make a symbol and use it over a Half Wall ...works okay for a few Areas but is a bit more time consuming if you have a lot to do ....
