Reggie11 Posted December 10, 2017 Share Posted December 10, 2017 Link to comment Share on other sites More sharing options...
Greg_NY61 Posted December 10, 2017 Share Posted December 10, 2017 Use CleanUp plugin by ThomThom in Sketchup before you export your model. Link to comment Share on other sites More sharing options...
Reggie11 Posted December 10, 2017 Author Share Posted December 10, 2017 Hi Greg - Thanks for the reply! I'm new to Sketchup and can't even find plugins in my extensions drop down. I ran the cleanup and is it possible I don't have enough memory? I run Chief Architect CAD software all the time and don't seem to have any memory troubles. Thanks! Davia Link to comment Share on other sites More sharing options...
Kbird1 Posted December 10, 2017 Share Posted December 10, 2017 Looks like a Error in detection of the Card ...it says you have a 6GB 1060 , that only has 1mb of Ram ....which isn't possible.... you can check the Render Tab in Chief's Preferences under VideoCard Status... for what it detects too. With a 6GB card like mine and yours it May say 4GB though (4095mb) , that is cos the memory may not be in one physical block and it only sees the 1st FrameBuffer as it is called. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 10, 2017 Share Posted December 10, 2017 Those "lines" are the edges of 3D faces (triangles) that as Greg said, you should remove in Sketch Up before export.In Sketch Up you select and then delete the offending 3D faces, if you make a mistake just "undo" but you do clean it up first before export as a .skp to Chief DJP Link to comment Share on other sites More sharing options...
