CBRF23
Funky Footers?
I've got a problem with unwanted steps in my footers.
I've checked the foundation tab of the wall properties for each wall, and I've checked the room properties to ensure the stem wall depth and footer depth/sizes are all set the same.  For whatever reason, they are not drawing the same depth footers, and I'm getting these really awkward steps.  They weren't like this in an earlier version of the plan, and I have no idea how they got broken or how to fix them.
Plan_171127.zip
I had this issue the other day when dealing with furred walls. The only solution I was able to come up with just to play with the stemwall heights in the Room Specification DBX.
Also, it looks as though some of your footings aren't lining up. You can adjust this in the foundation tab in the the same DBX.
Your double garage is set to default room height but the rest of the rooms are not. This is where you are getting the stepping from. Not sure if you want that for your rooms or the garage.
5 hours ago, CBRF23 said:
''I've got a problem with unwanted steps in my footers''.
I marked on your  plan where I corrected, no floor, and floor Elevation mishaps. Cottage Lane test.plan
 As you can see I fixed the drive way also... still a little steep, but looks better...
5 hours ago, 7654321 said:
Hi, 7654321 the test plan you attached still has the same problem (see screenshot).
I don't think the floor heights are the problem.  In fact, as an experiment, I changed the floor heights back to what I wanted in your file, and there was no change to the stem walls.
I think David James is probably on the right track - just go in and manually adjust until they line up.
I really don't understand why chief is doing what it's doing, but at least I can work around it.  It is strange to me though, if all rooms are set to the same stem wall height and footer depth (125 3/8"), why would there be any variation in the plane of the footings?
You should be able to select each footing / wall and adjust the footing depth from that DBX. After all footings are just walls with footings and create rooms .
    27489
    ChiefRochelle
    ChiefRochelle
  • Similar Content
    • By Designer100
      Is there a way to add pre Mfg. brick to outside of the foundation above grade that does not affect the porches etc or parts you do not want it?
      Newell Cheatheam
      www.newellsdesigns.com
      newell.cheatheam@gmail.com
      x11
    • By DRyeHD
      I've looked for a thread on this topic but cannot find one.  Typical construction is CMU stem wall on footing and slab.
      I would like to show outside edge of foundation block and all thickened slab areas (for bearing walls and posts).  I see the foundation block on floor "0" and the thickened slab (under bearing walls) and post footings on floor "1".  I would like to display all this on one layout and add dimensions for concrete, plumbing, and other under-slab work.
      What is the best way to do this without redrawing a separate plan to accommodate these items?
    • By CRHDesign
      Is there a room dialog to prevent this from happening? Ideally I want to make the cantilever a "cantilever" room and have it not generate walls under the cantilever with auto rebuild foundation walls on. Unless there is an easier way? Copying the balcony room settings ends up generating walls like the attached picture, still generating walls under cantilever. Feel like I'm missing something very simple.
    • By Designer100
      I cannot get the floor joists to  build.It originally a regular slab home.  but now it is pier and  beam with concrete  block around preiemerter at 8' o.c. or wha ever engineer specs out.  I cannot the the floor joist to build on first floor, cannot garage to show 4" drop with preimerter  walls and regular lab,garage left wall to close in. Rear deck will not show up in rendering either.
      FFE 61.00, top of cmu  blocks 60.00, existing grade 57.30', top of grade beam 57.33. garagefloor 52.33 8 cmu blocks abovegarage slab.perfer 12" all around outside of garage foundation.
      I would appreciate getting the first floor joists to be installed. and the other issues.
      Plan 5661LAF.GARAGE.PIER&BM.zip
    • By JimAlsup
      Hello All,
      I'm trying to figure out the best way to do the foundation for an addition to our 1955 home.  The existing home crawl space is minimal.  Perimeter stem wall is 18 inches with 4/6 girders resting on the sill and footings/posts at 4' O.C. .  Flooring is 2x6 T&G floor boards resting on the girders.  Not sure if that meets modern code.
      For the new foundation area I was thinking of using 2x8 joists for the floor framing and matching the existing stem wall.  I cannot use wider joist without raising the floor as I cannot lower the stem wall height due to code requiring 8" min stem top to group level.  The addition needs to span distances beyond the 12' span distance so I need to support them in some way.  Girders with posts seems reasonable, but I'm concerned about the crawl space height.   2x8 joists on 18" 16" O.C is tighter than the existing foundation which has 18+5.5 and widely spaced girders dropping it to 18".  The new foundation with 4x8 joists at 16" on center and girders would drop the bottom the height to 12" under the beams which seems very tight.  I think the code allows for 12", but is it bad practice?  Am I wasting my time worrying about this?
      I have a few ideas on increasing the clearance, but I don't know which would work best and what the cost trade offs are?
      1. Move the 4x6 girder to foundation stem wall height and then attach joists with joist hangers rather than resting on top.
      2. Build internal foundation footing/stem walls as needed to close 2x8 spans to 12' or less (leave access openings)
      3. If legal, copy the existing floor structure.  I'm guessing the 4/6 girders and T&G flooring is likely more costly.
      4. Extend the addition's stem wall and interior ground level down 6 inches.  Slope the soil away from the existing foundation 2" a foot. Excavation and concrete costs go up.
      Thoughts?
      Thank you,,
      Jim
