Bearing wall footings
ChiefuserLarkin
Yes. It's an annoyance. I think you have an invisible wall that the footing is terminating into. The footing only draws from the end point of the wall. You can't edit the footing termination with the "Edit Wall Layer Intersections" button to go any further. That tool is only good for the wall itself, not the footing. I was thinking today about drawing the footings separately from the walls so I could work around this limitation.
  • 2 years later...
I realize this thread is pretty old, but was anybody able to find a solution/workaround to this issue?  I'm having this same problem.  It seems to me that Chief should be able to do this since in the real world footings usually extend past bearing walls.
