Doug_N Posted October 30, 2017 Share Posted October 30, 2017 (edited) In the attached images, I am trying to get a uniform height in the foundation walls where the garage attaches to the house. The wall section in question defaults to the garage structural detail. Any comments would be welcome. Edited October 30, 2017 by Doug_N Tried to upload plan file, but it failed Link to comment Share on other sites More sharing options...
Doug_N Posted October 30, 2017 Author Share Posted October 30, 2017 Angle Garage Addition.plan File added to see actual work in progress Link to comment Share on other sites More sharing options...
Doug_N Posted October 30, 2017 Author Share Posted October 30, 2017 Yes I tried that, it goes back to being the shorter wall. Link to comment Share on other sites More sharing options...
Doug_N Posted October 30, 2017 Author Share Posted October 30, 2017 ok, I will give it a shot Link to comment Share on other sites More sharing options...
ShaneK Posted October 30, 2017 Share Posted October 30, 2017 Eric has the solution. Room adjacent to garage, set all structural tabs to default; break wall where you want; grab it and pull it up. Angle Garage Addition mine.plan 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 30, 2017 Share Posted October 30, 2017 because you have manually played with the foundation and auto rebuild is off you will need to do as Eric and Shane suggested and break the wall and do it manually. M. Link to comment Share on other sites More sharing options...
Doug_N Posted October 31, 2017 Author Share Posted October 31, 2017 Hmm, I have tried that but no joy. If you have done it, can post the file so I can see it? Link to comment Share on other sites More sharing options...
Doug_N Posted October 31, 2017 Author Share Posted October 31, 2017 When I break the wall, and then try to drag it up, all of the garage walls go up with it. Link to comment Share on other sites More sharing options...
Doug_N Posted October 31, 2017 Author Share Posted October 31, 2017 ok, I will give it a shot Link to comment Share on other sites More sharing options...
Doug_N Posted October 31, 2017 Author Share Posted October 31, 2017 Thanks Shank Link to comment Share on other sites More sharing options...
