conwaynorth1 Posted October 16, 2017 Share Posted October 16, 2017 I want one wall to extend 2" beyond another at an intersection but it always snaps back to create a 90 degree corner. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 16, 2017 Share Posted October 16, 2017 To add to what Eric suggested. I would recommend all users add their own Room Divider wall type that has a thickness of something like .01". This wall type can be used to define a room without changing size on you, and can more effectively be used for things like the above example as it will give you something to snap you main layer to suing the Edit Wall Layer Intersections tool... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 16, 2017 Share Posted October 16, 2017 It's also useful to have that wall type defined with either a "Blank" linestyle or a "white/background color". But you can also just set it as "Invisible". Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 16, 2017 Share Posted October 16, 2017 I like to break that 2x6 wall and reverse it and it should stick, but extend it like 2' beyond the other wall and just slide it back. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 16, 2017 Share Posted October 16, 2017 7 minutes ago, solver said: Any recommended changes to this, Michael? Nope. As long as that main layer thickness is actually .01" ( which it may be… hard to tell unless you change your number style to decimal inches) you should be good with that. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 16, 2017 Share Posted October 16, 2017 5 minutes ago, DRAWZILLA said: I like to break that 2x6 wall and reverse it and it should stick, but extend it like 2' beyond the other wall and just slide it back. I like to actually use a different Wall Type since both sides will be an exterior finish. We still need to have the sides reversed to prevent Chief from thinking it should be snapping to the corner. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 16, 2017 Share Posted October 16, 2017 I think in his case he would use a stucco both sides wall anyway Link to comment Share on other sites More sharing options...
conwaynorth1 Posted October 16, 2017 Author Share Posted October 16, 2017 Thank you all. DZ the break and reverse worked quickly and perfectly. Link to comment Share on other sites More sharing options...
Condor0811 Posted May 18, 2025 Share Posted May 18, 2025 All of this sounds great, but how will the framing plan be affected?? Link to comment Share on other sites More sharing options...
