Arkad7 Posted October 8, 2017 Share Posted October 8, 2017 How do I stop Chief Architect from changing multiple rooms/levels when I change the ceiling height of one room? On a split level house, if I change the height of the kitchen, all the walls on the adjoining level drop to the height of the kitchen wall. So the kitchen wall is 9 feet, and the bedroom walls are 5 feet. If I change the bedrooms back, the kitchen wall becomes 14 feet tall. The kitchen isn't even touching the exterior wall between the two levels. I've tried room dividers to separate the two. I've only had the program for a couple weeks, and I'm at a standstill. Link to comment Share on other sites More sharing options...
johnny Posted October 8, 2017 Share Posted October 8, 2017 You must start with the uppermost level first and work your way downward in setting floor levels. This is the way Chief needs it to be apparently. So if you want to change your lower floor level you have to change the upper floor. If you search on the forum there are some good vids....look for Scott Hall vids. He has a YouTube channel too. Link to comment Share on other sites More sharing options...
MarkMc Posted October 8, 2017 Share Posted October 8, 2017 There's also several related vids on Chiefs support site. https://www.chiefarchitect.com/search/?default_tab=video&q=split+level Link to comment Share on other sites More sharing options...
Arkad7 Posted October 8, 2017 Author Share Posted October 8, 2017 I've gone through some videos about split-levels, but I'll go through them again. I've got the home laid out; I'm still trying to find something to address this problem specifically. Starting at the top would be difficult for a cape cod style, which essentially depends on the lower level to dictate what's available upstairs Link to comment Share on other sites More sharing options...
BrownTiger Posted October 9, 2017 Share Posted October 9, 2017 You draw (multi-)split-floorplan as it is flat: floor one, floor 2, etc. After the plan is drawn, but before the roof... select the rooms at the top floor that you want lowered, go into the structure tab and and change Floor (C) value. Now move to the lower floor(s) and do the same thing. Here is my old multisplit plan, wasn't that difficult. Staircase was a nightmare, as I could never get it to understand that I want to stop right rail at the wall. Link to comment Share on other sites More sharing options...
Arkad7 Posted October 9, 2017 Author Share Posted October 9, 2017 Wow, that's fantastic! You're obviously much further up the knowledge curve than I am! :-D Link to comment Share on other sites More sharing options...
Arkad7 Posted October 9, 2017 Author Share Posted October 9, 2017 I can't seem to find the Floor Value. This is what I'm getting on the Structure Tab. But I'm still looking Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 9, 2017 Share Posted October 9, 2017 Look at values "C" & "L" in that dbx. Once you have those correct, go to the room below and edit the "Ceiling" Structure or Finish "J" to make up the difference. I usually use the "J" and just add an Air Gap and Joist Size above the Drywall. Link to comment Share on other sites More sharing options...
