basilbabaa Posted October 5, 2017 Share Posted October 5, 2017 What is the simplest way to create a 3 part wall? I need to take the metal wall above the block wall and split it where half is translucent fiberglass and the remainder remains metal... Thanks Link to comment Share on other sites More sharing options...
glennw Posted October 5, 2017 Share Posted October 5, 2017 You could try using a pony wall with the top wall turned into a solid railing using a metal material. The transparent top section is then a tall top rail using a glass or other transparent material. This will allow you to work with the wall structure as all one wall. Or did you want it this way? Link to comment Share on other sites More sharing options...
javatom Posted October 5, 2017 Share Posted October 5, 2017 You need 2 floors to do this. Just make the upper floor room def. "open below". That way you get another wall to work with. I'm not sure but I think this may be what glenn is doing. Link to comment Share on other sites More sharing options...
glennw Posted October 5, 2017 Share Posted October 5, 2017 Javatom, No, not another floor. I thought I explained it pretty well - but obviously not well enough. It is a pony wall with the upper wall defined as a solid railing with a tall top rail. The top rail is the third wall level, the solid rail is the middle wall panel and the lower pony wall is the bottom wall level. All one wall. All on one floor. Link to comment Share on other sites More sharing options...
johnny Posted October 5, 2017 Share Posted October 5, 2017 Glenn, can you save the file you did and share with us? Id personally like to review the makeup of the wall. Link to comment Share on other sites More sharing options...
glennw Posted October 6, 2017 Share Posted October 6, 2017 Johnny, Here you are wall.plan 1 Link to comment Share on other sites More sharing options...
Kelly_K Posted October 6, 2017 Share Posted October 6, 2017 2 hours ago, javatom said: You need 2 floors to do this. Just make the upper floor room def. "open below". That way you get another wall to work with. I'm not sure but I think this may be what glenn is doing. Very clever Glenn - I love the out of the box thinking, but I think I would take aim at what javatom suggests because you would have better control over the 3 wall type layers. Link to comment Share on other sites More sharing options...
