mtldesigns Posted October 2, 2017 Share Posted October 2, 2017 Please see the attached view and plan. I have an open below room that will need additional windows located on the second tier. I can put the windows in, but the walls are not "cutting out": Any help will be appreciated. Everywhere else in this house, no problems of second floor windows.. but they're all straight walls. Thanks in advance CURVED WALL ISSUE.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted October 2, 2017 Share Posted October 2, 2017 Delete the window in the center above the middle one and select all the others and hit ctrl +c and go to level 2 and hit crtl +alt +v and everything should be fine. This can be done in 3D or plan view the same way. Sorry but I am not really sure how it got fowled up the first time but I hope that helps you out. Link to comment Share on other sites More sharing options...
mtldesigns Posted October 2, 2017 Author Share Posted October 2, 2017 hmm.. somethings not right then. I did what you suggested (tried b4 also) and this is what I get. I couldn't do it in the file I attached earlier, but you could. Weird... Link to comment Share on other sites More sharing options...
Chopsaw Posted October 2, 2017 Share Posted October 2, 2017 And I was just about to update to 19.3.1.8 maybe I should not. What version are you running? The two curved walls are ever so slightly out of alignment in your test plan but that did not seem to cause a major issue. Link to comment Share on other sites More sharing options...
mtldesigns Posted October 2, 2017 Author Share Posted October 2, 2017 I have the most updated version.. just did last week. I noticed the miss-alignment too. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 2, 2017 Share Posted October 2, 2017 13 minutes ago, mtldesigns said: hmm.. somethings not right then. I did what you suggested (tried b4 also) and this is what I get. I couldn't do it in the file I attached earlier, but you could. Weird... looks like your default wall heights are screwed up..post the primary .plan Link to comment Share on other sites More sharing options...
Chopsaw Posted October 2, 2017 Share Posted October 2, 2017 Let me try the update and see if it still works after with your test plan. Link to comment Share on other sites More sharing options...
mtldesigns Posted October 2, 2017 Author Share Posted October 2, 2017 I thought the same too about the wall heights, but the attached plan has correct wall heights and that does not seem to be the issue. Link to comment Share on other sites More sharing options...
javatom Posted October 2, 2017 Share Posted October 2, 2017 Your walls do not line up. Go the the curved wall on the upper level and use the align with below tool 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted October 2, 2017 Share Posted October 2, 2017 Seems to work just fine with 19.3.1.8 Why don't you hook up with Rene on Team Viewer and show him what is going on in the real plan. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 2, 2017 Share Posted October 2, 2017 9 minutes ago, Chopsaw said: Seems to work just fine with 19.3.1.8 Why don't you hook up with Rene on Team Viewer and show him what is going on in the real plan. 19 minutes ago, mtldesigns said: I thought the same too about the wall heights, but the attached plan has correct wall heights and that does not seem to be the issue. https://www.teamviewer.us/downloads/?#cta-click-remote-support PC download, PM me and I can help you get it up and running and Thanks Chop Link to comment Share on other sites More sharing options...
mtldesigns Posted October 2, 2017 Author Share Posted October 2, 2017 Thanks Java.. As I was getting ready to hit Rene up on Teamviewer, I saw your post. I knew it was off by a hair.. but didn't think that would make the difference, but it did! To test this theory, I made another exterior straight wall, with a mild offset, and windows come in fine.. but it doesn't on curved walls. Learned something else today. Thanks everyone. Link to comment Share on other sites More sharing options...
