cabinet ends against angled wall (but doesn't???)
DianeP
I just use a thin cabinet Like 4" deep ,in this case, so you can keep your toe kick. Also use a custom countertop. The cabinet schedule will read it wrong so you would have to fix that or don't use dimensions in the schedule. Sink could be a problem though. Some people use a an angle front base cab and check back matches front and place it backwards in the plan
  • Upvote 2
There must be something I am missing on your solution Joe.  When I put in a cabinet and make it angled front it still looks rectangular.  Same when I have back match front. Haven't used angle front before and would like to learn what I am missing.   Thanks!!
You have to adjust the depth of the sides.  The attached pics show how it works.  I set the back to have a "Left Door" and the Front to have just a "Blank Area".  I also suppressed the "Toe Kick" and I would create a separate base for the "Toe Kick" using a PSolid.
  • Upvote 2
