DianeP
cabinet ends against angled wall (but doesn't???)
Is there a way to have the right side of the cabinet angle to a 45 degree to tuck in beside this wall? Thanks a bunch!
I just use a thin cabinet Like 4" deep ,in this case, so you can keep your toe kick. Also use a custom countertop. The cabinet schedule will read it wrong so you would have to fix that or don't use dimensions in the schedule. Sink could be a problem though. Some people use a an angle front base cab and check back matches front and place it backwards in the plan
  • Upvote 2
Another way to do it is to use an "Angle Front Cabinet and set the Back to match the Front.
Then just turn the Cabinet around 180 degrees.
There must be something I am missing on your solution Joe.  When I put in a cabinet and make it angled front it still looks rectangular.  Same when I have back match front. Haven't used angle front before and would like to learn what I am missing.   Thanks!!
You have to adjust the depth of the sides.  The attached pics show how it works.  I set the back to have a "Left Door" and the Front to have just a "Blank Area".  I also suppressed the "Toe Kick" and I would create a separate base for the "Toe Kick" using a PSolid.
  • Upvote 2
    27825
    ChiefDallas
    ChiefDallas
