raltd9245 Posted September 6, 2017 Share Posted September 6, 2017 IS there a way to turn off interior walls only. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 6, 2017 Share Posted September 6, 2017 Not by default but one could create a custom layer called "Walls, Normal, Interior" then placing only interior walls on that custom layer you could then turn off visually interior walls only. DJP Link to comment Share on other sites More sharing options...
raltd9245 Posted September 6, 2017 Author Share Posted September 6, 2017 To expand my question. I started the model with 10' ceiling and now want to change to 8' ceilings for the entire house. HELP Link to comment Share on other sites More sharing options...
glennw Posted September 6, 2017 Share Posted September 6, 2017 8 hours ago, solver said: Change your defaults. The ceilings will follow. Just to clarify what Eric said. This only works if the default is being used and none of the room heights have been changed manually from the defaults. Link to comment Share on other sites More sharing options...
RL-inc Posted September 7, 2017 Share Posted September 7, 2017 Will need to rebuild or manually lower roof planes as well if the have been created Link to comment Share on other sites More sharing options...
