icestorm-5456 Posted June 26, 2017 Share Posted June 26, 2017 How do I move Chief X9 to a new laptop? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 26, 2017 Share Posted June 26, 2017 Deactivate that license on your current PC, then go to your "Digital Locker" at Chief Architect.com, download and install on your laptop. All the data you will need is in your digital locker on line to do this. In terms of custom materials, plan and layout files must be copied to One Drive, Google Drive or Dropbox or just some portable media and then transferred to your new laptop. It is not hard to do. Just watch what you are doing while you are doing it and you will be fine. There afterwards you can only use one license at a time,deactivating one and then using the other. DJP Link to comment Share on other sites More sharing options...
mtldesigns Posted June 27, 2017 Share Posted June 27, 2017 You will also need to reload all of your catalogs, at least I had to. That's what takes the most time. Other wise, do what David mentions above.. and you should have no problem. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 27, 2017 Share Posted June 27, 2017 there is a Migration Guide here: https://www.chiefarchitect.com/support/ There is also a few tutorials in the KB.... https://www.chiefarchitect.com/support/article/KB-00001/migrating-chief-architect-to-a-new-computer.html https://www.chiefarchitect.com/support/article/KB-02899/manually-installing-core-catalogs-for-chief-architect-premier.html Link to comment Share on other sites More sharing options...
