separate roof height in same building
SMC2992
I don't know how to handle the portion i circled, when i remove the straight wall this is what i get, I need that the roof of the portion over the doors should be at 10' however an open window has been created above that location. see the pic
-Salah
MI room 2.plan
  • Downvote 1
I probably don't understand your intent, but there's nothing preventing you from drawing a flat roof around the perimeter of the building. Just draw a roof plane, set the pitch to 0, and shape it as necessary. Then draw a rectangle around the middle portion and convert it to a roof hole:
As far as the disappearing wall, you need a roof plane over that bay. Any roof, really:
