capitaldesigns Posted May 5, 2017 Share Posted May 5, 2017 I input an existing master bathroom that was a platform bathtub. The client wants to remove the platform bathtub and replace it with a free standing bathtub. When I removed the platform bathtub, which I used polyline solids to make the platform, I see that the baseboard molding is missing on the walls where the platform was. How do I get the baseboard molding to show on those walls ? Thanks, Mike Niami_Kitchen_Remodel_2.zip Link to comment Share on other sites More sharing options...
Griffin Posted May 5, 2017 Share Posted May 5, 2017 Nice. Draw a CAD line in plan along the wall. Convert it to a 3D Molding Polyline line. Open the object and add your molding from the library. Link to comment Share on other sites More sharing options...
MarkMc Posted May 5, 2017 Share Posted May 5, 2017 open the room dbx, moldings, use default, change to 5" to match the other baseborad Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 5, 2017 Share Posted May 5, 2017 Select the Room and then "Create Room Molding Polyline". Click any segment that doesn't have the Molding and check "Molding on Selected Edge. Link to comment Share on other sites More sharing options...
capitaldesigns Posted May 5, 2017 Author Share Posted May 5, 2017 Eric, That area with the cabinet and the enclosed space to the right are a part of the chimney. The chimney is the same width from bottom to top. They took a part of the chimney on the second floor and made it a part of the master bathroom. I need the walls of that area to extend above the roof with the rest of the chimney. I did not know how to do that if that area was included in the master bedroom so I made it into 2 separate rooms. Thanks, Mike Link to comment Share on other sites More sharing options...
