capitaldesigns
Base board molding not showing
I input an existing master bathroom that was a platform bathtub. The client wants to remove the platform bathtub and replace
it with a free standing bathtub. When I removed the platform bathtub, which I used polyline solids to make the platform, I see
that the baseboard molding is missing on the walls where the platform was. How do I get the baseboard molding to show on
those walls ?
Thanks,
Mike
Niami_Kitchen_Remodel_2.zip
Nice.
Draw a CAD line in plan along the wall.
Convert it to a 3D Molding Polyline line.
Open the object and add your molding from the library.
open the room dbx, moldings, use default, change to 5" to match the other baseborad
Select the Room and then "Create Room Molding Polyline".  Click any segment that doesn't have the Molding and check "Molding on Selected Edge.
I'm with Mark -- set to use the defaults, if they are correct.
Look at the ceiling above the small room shown below.
Not sure why it's a room instead of being part of the larger space.
Eric, That area with the cabinet and the enclosed space to the right are a part
of the chimney. The chimney is the same width from bottom to top. They took a
part of the chimney on the second floor and made it a part of the master bathroom.
I need the walls of that area to extend above the roof with the rest of the chimney.
I did not know how to do that if that area was included in the master bedroom so I
made it into 2 separate rooms.
Thanks,
Mike
    27988
    RGerbig
    RGerbig
