mdarch47 Posted June 27, 2014 Share Posted June 27, 2014 I am having some trouble with a seemingly simple issue. Not getting frieze boards to show up consistently..mostly on gable ends. I am sure it is a simple fix but have not been able to pin it down. Any help is greatly appreciated. See attached plan file done in X6/64bit. Thanks, Michael Dolce AIA Architect Link to comment Share on other sites More sharing options...
joey_martin Posted June 27, 2014 Share Posted June 27, 2014 Well.....if you have or find the "simple" fix to the seemingly random missing frieze boards, I would love to know what it is!! I have dealt with this problem for all the years I have worked with Chief (v9) and honestly have no real explanation to how or why they show up and then don't. Same with roof returns. Best solution I have come up with, is to ignore the fact that they are missing, and many times they will re-appear like magic. If they don't re-appear, I will manually edit them when completing my final elevations and call it a day. I know it sounds like I'm being a smart a$$, but I spent countless hours back in the day trying to figure out what I was doing to cause this issue, and finally cam to the realization that I am not the problem. And...to make matters worse, when I have reported the problem and sent a plan file to be looked at.....you guessed it, the frieze boards were there. Good luck, and happy Chiefing! Link to comment Share on other sites More sharing options...
Kbird1 Posted June 27, 2014 Share Posted June 27, 2014 no attached plan I can see.....? Link to comment Share on other sites More sharing options...
mdarch47 Posted June 27, 2014 Author Share Posted June 27, 2014 Let me try sending attached file again...which I had thought was attached to begin with? MPD-Architect-McComas-Res.zipFetching info... Link to comment Share on other sites More sharing options...
basketballman Posted June 29, 2014 Share Posted June 29, 2014 Michael: Seems to be related to gable end overhangs ...... When I add even a small amount it now allows gable frieze boards ... Not sure what the minimum is, but you can experiment .. Link to comment Share on other sites More sharing options...
