SNestor Posted March 20, 2017 Share Posted March 20, 2017 Wondering why I get this line showing in vector view where the brick on the gable wall meets the wall below? The two walls are aligned...I checked this. Is this typical...or is there something I can do about it? Let me know if I need to post the plan to get a good answer to this question... Also...regarding Vector Views. When I'm in a camera view with the Vector View setting...and I turn a layer on or off...the screen re-draw is kind of like a movie...it fades in or out depending on what I've done. Is this normal behavior? Also...is it correct that the vector view would be slower than standard view when scrolling on screen? Thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 20, 2017 Share Posted March 20, 2017 You might also check that there is no gap between the two wall poly-lines to reduce the instances of unwanted lines but when sent to layout your best bet is adding (when found to be missing ) or eliminating such lines is the "Edit Layout" tool. It terms eliminating such lines before sending to layout, your choices are limited but with the use of the edit layout line tool you can make vector view objects near perfect. DJP Link to comment Share on other sites More sharing options...
SNestor Posted March 20, 2017 Author Share Posted March 20, 2017 To eliminate the line in Vector View...all I had to do was adjust the material definition using the "rainbow" tool. I adjusted the "vertical position"...moving the brick down 1.5"...and BOOM...the line was gone. Not sure why...but it's fixed and that's all I needed. So...if you ever encounter this...start with the "pattern" in the "material definition" dialogue box. Make a small adjustment to the "vertical or horizontal position". It may take trial and error to find the correct amount of movement needed to "fix" the line issue. Before: After: 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 21, 2017 Share Posted March 21, 2017 As for the delay or fading, I have turned off "Edge smoothing when idol" and I now don't get that anymore. I think it depends on your system weather you need it or not. Link to comment Share on other sites More sharing options...
