JECORMIER Posted January 26, 2017 Share Posted January 26, 2017 Sooo, I have some ideas as to how I would go about creating this lower level space but I'm not quite sure how to go about it. I'm sure someone has drawn one of these and can get me headed in the right direction. See attached picture... Thanks a bunch Link to comment Share on other sites More sharing options...
Ridge_Runner Posted January 26, 2017 Share Posted January 26, 2017 Are you talking about the arches in particular? Need a little more specific information. I would use polyline solids drawn in elevation for the arches. Pick your poison for the columns - slabs; primitives; etc. Link to comment Share on other sites More sharing options...
rlackore Posted January 26, 2017 Share Posted January 26, 2017 The last time I did an arcade I used fat walls with arched openings. It worked well enough. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 26, 2017 Share Posted January 26, 2017 yep, I would use real arched openings to a post ( easier to change if you have to) and p-solids for the column's that would cover up some of the wall below.. Link to comment Share on other sites More sharing options...
Evolution Posted January 26, 2017 Share Posted January 26, 2017 I do the same as Robert. Link to comment Share on other sites More sharing options...
JECORMIER Posted January 26, 2017 Author Share Posted January 26, 2017 Great ideas! Thank you very much for your input. J Link to comment Share on other sites More sharing options...
