Randyc Posted January 25, 2017 Share Posted January 25, 2017 Boss wants me to explore a way to get a higher quality image of exteriors only.. is that done by ray trace? or is there another way that is faster...ray trace is on pass 830 and at 45 minutes ugh Link to comment Share on other sites More sharing options...
GeneDavis Posted January 25, 2017 Share Posted January 25, 2017 Show boss the exterior renderings on Chief's website. If boss wants more, you have a problem. Rendering takes time no matter what you use. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 25, 2017 Share Posted January 25, 2017 If it is bad at 50 passes then it will still likely be bad at 830 passes. Post a the image and we might be able to provide you with some guidance. Graham Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 25, 2017 Share Posted January 25, 2017 Not sure if the helps, just ran this. Please no comments on the architecture, this is an interior first floor project; just threw a roof on it and a bit of landscaping. 11 passes in 1 min 41 sec. 1200 X 600 px Graham Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 25, 2017 Share Posted January 25, 2017 You can set the resolution in the ray-trace DBX to whatever you need. Link to comment Share on other sites More sharing options...
