Designer100 Posted January 20, 2017 Share Posted January 20, 2017 i would appreciate any advise /help on raising this brinck fireplace 30 in above peak roof (it is existing in this remodeling) and get rid of the walls sticking above the roof w/o affecting family room catheral ceiling. Thanks, Newell 713.395.7622 Tharp.Ben Remodeling.plan.7z Link to comment Share on other sites More sharing options...
Designer100 Posted January 20, 2017 Author Share Posted January 20, 2017 can the soffits match the catheral ceiling and stop at clg. Link to comment Share on other sites More sharing options...
Designer100 Posted January 20, 2017 Author Share Posted January 20, 2017 Thanks for advise Link to comment Share on other sites More sharing options...
Designer100 Posted January 20, 2017 Author Share Posted January 20, 2017 I have tried what you guys suggested and cannot get the furrr down to stay under roof, nor chimney to go above roof. I took elevation and does not let me draw furrdown. Also it is supposed to be cath. clg all across the family room and roof continues straight across same peak roof all across the house. Tharp.Ben Remodeling.plan.zip Link to comment Share on other sites More sharing options...
BrownTiger Posted January 20, 2017 Share Posted January 20, 2017 DSH spent a bit of time on the subject.... https://www.youtube.com/results?search_query=dsh+chimney Link to comment Share on other sites More sharing options...
Designer100 Posted January 20, 2017 Author Share Posted January 20, 2017 I have been trying for 3-4 hours . cannot solve the issue of family room and cath ceiling with, beam in middle and furr downs from top of bc to btm of cath. ceiling on each side of fireplace flush with fireplace wall on family room side. You can see roof is showing in picture. Remodeling existing fireplace needs to go thru roof. Issues with roof not looking right. I would appreciate any help. Tharp.Ben Remodeling.plan.7z Link to comment Share on other sites More sharing options...
dshall Posted January 20, 2017 Share Posted January 20, 2017 On 1/20/2017 at 9:54 PM, Designer100 said: I have been trying for 3-4 hours . cannot solve the issue of family room and cath ceiling with, beam in middle and furr downs from top of bc to btm of cath. ceiling on each side of fireplace flush with fireplace wall on family room side. You can see roof is showing in picture. Remodeling existing fireplace needs to go thru roof. Issues with roof not looking right. I would appreciate any help. Tharp.Ben Remodeling.plan.7zFetching info... Expand come on Newell, how can we open this file? It is not a CA file. Link to comment Share on other sites More sharing options...
digitecht Posted January 22, 2017 Share Posted January 22, 2017 Scot IT is a zip file. you have to unzip it. I think microsoft's compression tool can unzip it. Frank. Link to comment Share on other sites More sharing options...
Designer100 Posted January 23, 2017 Author Share Posted January 23, 2017 here it is unzipped. Tharp.Ben_Remodeling.plan Link to comment Share on other sites More sharing options...
MPDesign Posted January 23, 2017 Share Posted January 23, 2017 Newell, I used a skylight set to a hole. (uncheck skylight in dbx) Then in a elevation determined height above floor for 30" above ridge. In this case 222" above. Set ceiling height in the room to 222". The 2 side walls in dbx set balloon thru ceiling to get them to reach the roof. Tharp.Ben_Remodeling-EDIT.plan Link to comment Share on other sites More sharing options...
Designer100 Posted January 24, 2017 Author Share Posted January 24, 2017 Thanks. I just copied, pasted in place from 1s floor chimney to attic and solved issue. Link to comment Share on other sites More sharing options...
Designer100 Posted January 24, 2017 Author Share Posted January 24, 2017 how can I get the catheral wall toward fireplace to show correcting closing up clg. where you do not see under roof. I resent plan unzipped Link to comment Share on other sites More sharing options...
